To 4WD or Not To 4WD
HVACRoger
2021 L2501 Loader, Backhoe, LandPride Grapple, Tiller, Forks, Quick Connect
Dec 20, 2021
174
96
Wilson, NC
Estimate for cost of stone came in:
# 57 or #67 granite 18 Ton $1100 delivered
#4 granite 18 ton $1300 delivered
Tonnages based on 2" depth
7,388
Ouch -
Not sure if granite is routinely available around here.
Got a 20 ton load of crusher run April 2021. Top-dress driveway every 3-5 years.
$250 delivered. About a 15 mile trip one-way.
Bet it's more now, but not that much.
HVACRoger
Dec 20, 2021
174
96
Wilson, NC
Do I understand this correctly - the price of one tandem load of stone is $1100-$1300?
You understand correctly. Found that I have a quarry about 10-15 miles from my primary home. Delivery from there to primary home would be 18 ton load for $984
HVACRoger
Dec 20, 2021
174
96
Wilson, NC
Ouch -
Priced that also, 10 ton load $584
7,388
Roger - - Wow.
I wasn't advocating you change material. It's just what I bought last year.
Holy smokes! Those prices are startling.
I might try another pit/vendor. maybe two...
HVACRoger
Dec 20, 2021
174
96
Wilson, NC
Roger - - Wow.
Roger - - Wow.
Everything has gone crazy with prices!! We have seen a 30% increase in our HVAC equipment prices since 2019. They are limiting the amounts of duct materials we can buy per day. Afraid this Country hasn't seen the worst yet, Lets Go Brandon!!
Now, Yea, I was not thinking you were trying to get me to change materials. Figured since I had them quoting would get the crush run priced. Need to upgrade my drives at home in Wilson, about 300'. Had those put in early- mid 90's. Never had a problem with them, never had any fill added, just periodically drag them. They have settled, so time for more fill.
7,487
Just for giggles I called the local quarry. A 20T load of CR6 delivered (15
miles each way) is $626 including freight and tax. Their hauling charges are pretty steep and the local excavator I use has his lot right down the road and can probably beat that price hauling it for me.
I am surprised prices in a place like NC are that high.
6,993
Last time I got rock it was something like $600/load at 22 to 26 tons/load for a 175 ton order. That was 5 miles without any major road travel. They weren’t concerned about DMV weighing them so they were able to run heavy. About 40% of the cost was transport. Priced from 3 local quarries and that was the best deal at the time.
That was about three years ago. With the increases in fuel prices for the trucks and quarry machines I would expect that’s gone up. There’s so much road construction and general construction in our area the demand for rock is a bit crazy. That demand also impacts the paving prices. DOT is part of it but the seemingly endless new housing and commercial developments put a lot of pressure on the supply.
nbryan
Jan 3, 2019
1,444
956
Hadashville, Manitoba, Canada
The only time I have my tractor out of 4wd is if with light or no loads and just getting a to b like road travel, and when I don't want to dig up the sod or soft gravel with the front tires especially while turn sharply.
While working with heavy FEL loads always have the 4wd engaged. One bump can remove all the rear tires' traction and you're now freewheeling with 1000lbs of sand on the front and no brakes. A guaranteed butt-puckerer, at minimum. It took me ONE uncontrolled (albeit minor and nothing around to damage) front-wheels-only roll mishap to learn that real good. Took a few seconds to realize the brakes were suddenly useless and the only way to stop was to drop the sand load down to the ground.
HVACRoger
Dec 20, 2021
174
96
Wilson, NC
I decided to do the same since you replied. I called the quarry, its 11miles from my home.
#57 granite $33.00 per ton plus 6.75% tax
Crush run $26.00 per ton plus 6.75% tax
Delivery fee $180 to my location
So, it is a little better
Contractor is in line, I quess, if you account for profit margins. Also, numbers I listed were for coastal area, don't know where quarry is there.
HVACRoger
Dec 20, 2021
174
96
Wilson, NC
I don't want to live that, but minus my experience, something tells me I will during my seat time
7,487
Anybody that operates on slopes understands 4WD is needed for braking as well as pulling. If I decided to run full speed down the county road I would use 2WD. Anything else is 4WD.
HVACRoger
Dec 20, 2021
174
96
Wilson, NC
Wife has said " Hell No" to the asphalt. Said it's going to be decorative rock, that's why you have a new Kubota with all the play thingies that came with it. So, get this thing going and go play!!
YES MA'AM!!!
nbryan
Jan 3, 2019
1,444
956
Ok, but the OP just got a tractor, is asking good questions. It's really good to know these things before you go operating on a slope like I did 4 years ago as a 4WD FEL CUT newbie.
I gained that understanding by scaring myself a little, but the main thing as in anything with these machines is careful forethought before action, which when you're a new operator takes TIME.
Just take it all nice and slow. Think. Muscle memory takes time.
There are just too many things that can f-up with all the pedals, levers, huge # of implements of all kinds, small, powerful and relatively lightweight tractor units.
Now the OP has a heads up!
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Are you going to tear out the concrete or go over it?
jyoutz
Jan 14, 2019
3,634
2,736
Edgewood, New Mexico
Have you considered a concrete apron at the garage and then a gravel driveway? No idea how much drive length you are talking about for the $17000
That’s what I did. Concrete in front of garage long enough to park a car, then gravel the remainder of the road. Of course my road is 2100’ long.
HVACRoger
Dec 20, 2021
174
96
Wilson, NC
Being the concrete is very thick, was poured in 1980, its a great base so I am thinking just put rock over it. I will need around 3" 4" in-depth to meet garage slab. Will put some type of geotextile fabric down in the other places. Project is getting larger as the wife wants the area beside the garage and behind the garage done also.
HVACRoger
Dec 20, 2021
174
96
Wilson, NC
Dang, one thing about it, you can see who's coming before they see you!
HVACRoger
Dec 20, 2021
174
96
Wilson, NC
We are so tired of concrete cracking, main reason plus cost for rock drive idea. Everybody has always said to me, ' The only thing certain about concrete is its certainly going to crack".
