Tipper for atv trailer
yyri
b6000, rototiller, rear blade, atv trailer
Jun 19, 2023
26
58
Finland
So when I bought my B6000, I got atv trailer with it. It had no tipping mechanism for it, so I fabricated simple one for it as this was one of my first "larger" metal works at home.
It seems to work ok, scoop full of half dry wood lifted easily. It could've been taller but I thought I need to fit it inside garage/sheds without disassembling it and making it telescopic.
For next work I'm thinking of making a rear bucket, whipped out something in CAD already (I blatantly took ideas from already existing buckets, that may be ok as this is only for my personal use :) ). 3mm steel may be thick enough, as the b6000 isn't too heavy itself?
Caden
1979 B7100
Apr 16, 2026
293
161
Looks pretty good. One thing you may want to consider is that most dirt scoops are made to where you can hook them up so that they scoop in forward or reverse.
In your case maybe you only need to scoop in reverse, but if you ever use it for grading moving forward is nice.
I like the trailer dump, can the winch line double to help load the trailer?
3,127
One thing about the rear scoop I have is that it gets too loaded at back (closed) wall and won’t dump properly. So you might want to put a handle/lever to use to dump it when it refuses to dump on its own. I am probably going to add some hydraulic cylinder to mine just because I think that is “cool”. Also if you are planning on a pull type release lever, make it easy to pull by welding on a longer lever and think about how you intend to operate it (rope, rod, cable).
5,503
That is a very clever dump trailer sir!!!
Looks to be very nice craftsmanship, thanks for posting!!!
yyri
Jun 19, 2023
26
58
Finland
Thanks! Fortunately the trailer box was hinged so I had just to make the winch mast. I have to test sometime with logs if the winch can load them. Shops around here sell winch operated loading booms (for logs etc), but figured I didn't need one so I made this simpler version.
Thanks for the ideas for bucket, I'll take them in consideration and add the handle (some kind of quick removable design) to help dump the bucket :)
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
770
1,397
Baranduda, Victoria, Australia
Nice job on the trailer dump - looks great. I used 3 mm steel for the bucket I made for my front loader on my tractor which is only a little bigger than yours and it is surviving quite well, so I think 3 mm will be ok for your scoop.
