Thread tape, thread sealant, or ????
7,206
Okay, so I’ve read through this whole thread and have a question to add on. I have only ever used the cheap hardware store ptfe/Teflon tape for sealing and I absolutely hate it. For general water use cases, would it be accepted that a general purpose liquid sealant be a better option? I’m not a plumber by any means so I have been learning a lot from this thread. Most of the experience I have is related to soldering copper and installing fixtures and toilets. Which it seems recently most fixtures I’ve bought come with a small roll of tape and/or some sort of seal inside.
As I said in my first response - any thread sealant you want. That seems to have been drowned out in the noise. If you don't like tape use a residential plumbing paste from your box store..
It matters not a whit. This is a low pressure, low tech water line - not bombay door plumbing on a B2 nuclear bomber.
Trustable
l2501HST
Jul 5, 2022
397
411
Ah, yeah I must have missed it, appreciate the response. I was just curious after reading all the information on here, ill have to pick up some paste next time I’m out and see if I prefer that then.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
551
183
NZ
... recently most fixtures I’ve bought come with a small roll of tape and/or some sort of seal inside. ...
Probably tape because tape has no cure time and never (?) has a use-by date, contrary to (some/most/all?) liquid sealants. Not that a use-by date on liquid sealants has made much difference IMHO.
Same as pipe-sealing PTFE cord - no use-by date. Haven't seen it recommended for tractor hydraulic systems tho' (a nod to the OP's question).
Trustable
l2501HST
Jul 5, 2022
397
411
Oh yeah good point. I never thought of that, maybe the sealant hardens like old paint? And yeah after reading this tread and seeing the pressures involved in a hydraulic system, I’m a bit nervous to touch anything besides using the quick connects, but I’m gonna have to at one point probably.
JohnDB
Jun 9, 2018
551
183
NZ
... I’m a bit nervous to touch anything besides using the quick connects, but I’m gonna have to at one point probably.
Relax, you're among friends. If you've done a little searching on this forum/googling and still have any doubt, start a thread. (But NEVER start one asking for opinions on lubricants and filters) :)
Trustable
l2501HST
Jul 5, 2022
397
411
haha thanks! lubricants, filters
, and tire brands are a bad idea on any forum 😆. But I’d like to add a third function at some point so I’ll have to start reading some threads on here before I commit.
7,206
Adding a third function to a L2501/LA525 is easy, inexpensive, and not a contentious topic.
4,191
I will share another personal anecdote.
Late summer of 2024 I hired a local "handyman" to remove my old commercial gas range and install a new replacement. When hooking up the flex gas line he smeared the flare ends of the two adapters with the same PTFE paste he used on the taper pipe ends. When I objected he insisted it was required. First thing I did after he left was pull the range out and clean that crap off.
Sounds like a supervisory failure.
7,206
No, just people skills.
The handyman is not a gas fitter and is a reliable resource that has been a godsend during my health crisis. He continues to work forr me. There was no need to alienate him over something trivial that I could easily correct.
The expensive and argumentatuve general contractor I hired to renovate my porch was a different matter. He built a custom door that would not open and was botching my porch railing. That got his ass fired. I finished hanging the railing myself and my handyman rebuilt the door which was too much for me to handle. .
Early in my relationship with that GC he informed me he was "the engineer on this train". On his way out I told him "you may be the engineer on the train but i own the railroad".
wendol
L3800 HST
Feb 5, 2014
202
45
North Tx
For anyone that stuck around to see what was used on this little project........
I used Blue Monster PTFE Thread Tape (70885). Great success......no leaks, no drips. Strongly recommend.
4,191
@hokie: :love: Love the RR-Owner answer!
My previous post re: supervisor: I was in a similar situation: I had hired a man to do some welding and he was using 6011 rod on some structural members. I told him I wanted low-hydrogen rods … and offered him some 7018‘s I had on-hand.
He replied, “No… I prefer 6011’s …that’s all I ever use…”
I pointed out that since it’s MY hangar we’re building…. we’re going to use 7011’s or find a different welder.
(I ended up getting rid of him and hiring a fellow who’d been laid off the AK-pipeline when he took time-off to be with his sick wife. Best decision I could have made…. He turned out to be a damn-ARTIST with welding….(I enjoyed watching him weld up-side-down and using a mirror on the blind, back-side of the beams…. bending the rods 180-degrees to get them into the flanges.) Wow!
Anyway…that’s what I was thinking about in my previous post.…. wishing you‘d simply fired him and done it right first-time.
But alls-well that ends well.
5,279
Cool picture on the bottle too!!!
Butt I’m sticking with Rectum-Seal……..;)
