Swing arm hydraulic leaks
Todaczmoon
M62
Dec 19, 2023
M62 is leaking hydraulic fluid from under the throttle pedal when using the backhoe swing arm.
How do I access that area so I can pinpoint the leak?
mikester
M59 TLB
Oct 21, 2017
3,914
2,561
www.divergentstuff.ca
Start by taking the hoe off, get a set of wrenches and remove safety covers to see if you can identify where the leak is. Worst case scenario is take the rear wheels off, remove fenders, seat and floor pan.
Based on your question you might be better off to call your local dealer and have them fix it.
Todaczmoon
M62
Dec 19, 2023
Todaczmoon
M62
Dec 19, 2023
Thanks for your reply, haha, I’ll fix it myself though!
I asked largely because of the lack of information online, no exploded views. I didn’t want to just start taking things apart willy-nilly if someone with experience would be willing to suggest best procedure.
2,310
Illustrated parts list are here and can be used to see how things are put together or taken apart
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
368
526
SE, NM
I believe that's your loader valve in there. Those cover plates just bolt on.
