2020 SVL 75-2 loosing power. When you first crank it cold it has full power and runs smooth. As you work the machine for about 10minutes it will start to slow down. It will get to a point where it will barely turn with a loaded bucket. The engine starts to sound like it’s missing or chugging. If you let it rest at idle for about 5 minutes the idle will smooth out and you can get about another 5 minutes at full power before it starts dragging again. We have checked all the fuel lines. The lift pump seems to be functioning. Cleaned out the 90s on the water separator. New fuel filters. Tried to loosen the fuel cap when it starts slowing down to see if it was a vent issue. Nothing has worked. Any last ditch simple checks before I haul it to the stealership? Should still be under warranty but I like to rule out the Maintenance items firsts before it has to sit up there for weeks on end.
