Stripped oil plug threads lower knuckle
NorthwoodsLife
Oct 15, 2021
1,063
1,015
Wisconsin
Quick fix? As others mentioned.. the rubber bung you can usually find in the plumbing section at the hardware store. No hardware store?... Take a quarter and JB weld it over the hole. When you're ready to fix it right.. knock the quarter off with a punch, then drill and tap as others mentioned.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,978
3,117
Temporary fix- previously mentioned emergency plug. Like a small bilge plug on a ski boat. That'll get you by for a while.
Permanent- if the steel is as thick as I imagine, get the next size up plug and tap the existing hole. I'm OCD, so I could understand not wanting 2 different plugs in the same axle. It is still what I would probably do.
Pawnee
L2501
Jul 1, 2021
350
309
Ontario Canada
You could drill them both out.
Haha, I would not have suggested this if it were your tractor.
I'm OCD too.
