STRANGE Hydraulic Issues on L48/BT1100
DannyNewmanL48
Kubota L48
Apr 29, 2026
Harlem, GA
I recently purchased a used BT1100 to go on my L48 which has never had a backhoe on it. The seller disclosed that the swing function didn't work but no other info. I got it anyways with the BT1100 being basically unobtainable and it was still a great price. Brought it home on a trailer, and it sat on the ground for a week or so while I waited on the rest of my tractor side plumbing to come in so it could be connected. In the back of my mind, I sort of hoped that the issue would lie inside the previous owner's tractor, or at least be something super simple. Well, it's been anything but that. I need a hydraulic guru to step in and tell me something new, because I'm out of ideas. A new complete valve assembly is nearly $3,400 and I'm not looking to go there unless absolutely necessary. These are some fancy proprietary Husco 5000 series valves, looks like only available from Kubota and half the parts are discontinued.
Upon connecting to my tractor, as stated all the functions worked except for swing. I did feel like the rest of the hoe ran kind of slow/weak, but I'm accustomed to mini excavators so I don't really know what it's supposed to feel like on the L48. When you hit the swing function, the system simply dead heads and goes to relief. The swing cylinders do not move other than a slight attempt to move as you return the spool to neutral. If you cycle the spool about 10 times, you can get it to move a couple inches. Also, while cycling this spool, the other functions seem to lose some pressure momentarily. (I.E. when I cycle the swing spool, during that same moment that it moves an inch on return to neutral, the boom will also fall a little bit). Again, rest of the hoe works as intended. Maybe a little weak but I figure I probably just need to adjust the relief valve later. For those not familiar, the swing function on this backhoe is fed by a separate hydraulic pump than everything else. Just upstream of the swing spool valve is a "mid inlet" section where this pump feeds in.
First off, yes, the swing lock pin is removed.
- I tee'd in a gauge on the swing lines coming off the spool valve. No matter which way you operate the spool, both of the hoses instantly charge to 2500psi. It acts like there is no return.
- I have thoroughly checked all of the swing circuit plumbing, making sure no hoses are hooked up wrong. Everything matches the Kubota diagrams exactly. All hoses flow freely and have no damage.
- I have disassembled the swing cylinders, there is no damage to the bore, piston is intact, the seals even looked good. I got them replaced anyways.
- I have had the valve stack off the hoe, disassembled and checked that all the parts were there NUMEROUS times. I have even tried swapping the spool valves around to rule out a bad valve. The old swing valve works fine in a different position (I.E. boom, dipper), valves that worked before no longer work when placed in the swing position.
- I have swapped around the port relief valves in case one of those was bad, no change.
- I have tried connecting the swing valve to different cylinders just to make sure, no change.
- I removed every single spool and compared them, even tried swapping some around just in case the wrong one was in there, nope.
- From everything that is visible, everything inside the valve assembly looks exactly how it should. No trash, no corrosion, no visible cracks, no scoring, nothing. You can look straight through the return path and there's nothing in the way.
At this point, it seems to be a problem in one of the valve castings but I can't find it. What would cause this to happen?? I can't think of any logical explanation. You can shine a flashlight down the return path in the valve assembly and its wide open, absolutely no reason fluid should not be able to return down the path unless some part is missing or someone has reassembled it the wrong way. I've spent hours starting at Kubota diagrams and the WSM trying to find anything missing or put together wrong, but everything seems to match...
I've actually blown the outlet seal on the tractor's swing pump just from messing with this thing. The shut off plug on the bottom of the mid inlet casting is leaking like crazy when you operate the swing too... I'm just hoping someone has faced this and knows something I don't, because this thing has had my head spinning for weeks now. No hydraulic shop in my area has equipment to bench test the valve. I'm essentially on my own with this one.
Any ideas would be greatly appreciated!
ruger1980
L4310 w/La682, L225
Oct 25, 2020
590
255
CNY
If another function works on the swing spool when swapped you do not have a valve problem. Your post is a bit confusing but I believe that is what you stated in your post.
To me it sound smore like you have the crossover hose between cylinders incorrect. The barrel end of each cylinder must connect to the rod end of the opposite cylinder.
When you had the swing cylinders out did you try to manually move the boom to see if i was not seized in some way?
DannyNewmanL48
Kubota L48
Apr 29, 2026
Harlem, GA
I figured it would come across that way…. I tried my best lol.
- Everything is 100% mechanically free. Moves easily by hand with no hydraulics in play. With the hoses connected, it’s locked solid.
- I connected other cylinders such as an outrigger to the spool in question, no change.
- I took the entire valve stack apart, reassembled it in different order as to trade positions between the dipper valve and swing valve. The old swing valve worked just fine while it was in the dipper valve’s spot. The dipper valve started dead heading when in the swing valve’s old spot.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
590
255
CNY
First off stop disassembling the control valve and do not swap spools, they are usually different for different functions. There is also very little that can go wrong with a spool.
But to clear up your reply. You say no change when you swapped hoses/cylinders with the swing spool correct? So the cylinder you swapped to did not move the same as the swing cylinders did?
When you changed valves did you change just the spool or the entire section?
Do you have a WSM for the backhoe? A schematic would be very helpful in this case and I do not wan to trust another model is the same.
whitetiger
Nov 20, 2011
3,765
2,176
Kansas City, KS
Check the routing of your hoses between the cylinders. If they are correct, remove the hoses from the control valve at the cylinders and place them in a bucket.
Move the swing lever one way, then the other, and see if you get flow from each hose or just from one.
If the valve is good, the cylinders are good, and the hose routing is correct, you have a plugged hose or the pivot is seized.
whitetiger
Nov 20, 2011
3,765
2,176
Kansas City, KS
I did not realize that a different hydraulic pump fed the swing.
You probably have a failed coupler or tip on the "B" pump quick couplers. Screenshot (115).png
7,323
You probably have a failed coupler or tip on the "B" pump quick couplers. View attachment 173757
I know I am preaching to the choir but this seems to be the best post to do it from. The hydraulic circuit diagram makes things abundantly clear.
There is also a separate nanual selector valve on the tractor for that pump. For things to work properly the backhoe valve sections must be in the proper order, the hoses must be connected to the correct inlet sections on the backhoe valve, and both tractor side selector valves must be placed in the proper poisition whenever the hoe is attached/detached.
If the swing pump selector is not set for hoe operation the swing pump dumps directly to tank. There is no flow to the hoe outlet and if the hoe is connected no swing function.
If its set to the hoe position and the swing circuit hoses are not fully connected the pump is forced to continuosly unload at full system pressure via the tractor side relief. Thats a recipe for premature swing pump failure.
I would say there is a good chance the pump failure(s) and/or loss of swing function are the result of operator error.
At this point things are so muddled by all the incoherent switching and swapping anything is possible. The OP needs to put EVERYTHING back to original, read the operator's manual, and quit experimenting on circuits and valves he does not understand.
If there are still problems at that point he needs to ask for help on how to properly diagnose the problem(s). Breaking things with improper diagnostics can get real expensive.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,953
2,455
WestTn/NoMs
I'm posting this picture which I think you posted on the Facebook Kubota group. (BTW, should have come here first :)).
I'm also posting the mid inlet section, which I think you have, from the Husco 5000 tech document, available on-line. Since the swing function is isolated from the rest of the valve, troubleshooting this should be straightforward. If the problem is not due to a bad coupler, is it possible that the mid inlet section has been flipped over, or is the wrong part? As someone on FB pointed out, the section next to the mid inlet (boom?) has apparently been replaced. Maybe the inlet got reversed? I know it's unlikely since the o-ring groove would be backwards.
The other, highly unlikely, possibility I think of is that someone has installed an undrilled flow restriction fitting in there.
7,323
It IS straightforward. Put everything back to original and lets do that.
Am I correct in assuming new work sections are still available? I recall you found one somewhere.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,953
2,455
WestTn/NoMs
Probably so. There are a zillion implementations, port reliefs, hand, etc, etc. And they're not cheap, but I don't think that's OP's problem.
I bought a NOS stack built for a fork lift and used one section.
7,323
I dont think the valve its the probkem either. More likely @whitetiger hit the nail on the head with the coupler. We can test that by disconnecting the swing supply hose at the valve and watching the flow as the swing pump diverter is cycled on/off. I am tempted to say EZPZ but I have no clue how easy/hard it is to get to that connection.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,953
2,455
WestTn/NoMs
Looks like it's right there. OP probably still has the pedestal panel off.
DannyNewmanL48
Kubota L48
Apr 29, 2026
Harlem, GA
You are correct, any good known cylinder that I connect to the swing spool locks up and does not move.
And yes, I’ve tried both swapping the entire valve position as well as the spools themselves. Nothing changes regardless.
Yes I have the WSM. Have not found it to be much help. I have also looked at the husco documents and Kubota parts diagrams for probably hours.
DannyNewmanL48
Kubota L48
Apr 29, 2026
Harlem, GA
I’ll check it, but all the couplers are brand new as my tractor never had them and the backhoe was missing 2/3 as well. All just ordered from Kubota.
I’m not having trouble getting pressure, I’m having trouble getting return.
7,323
All of the valves share.a common return. Do you get flow out of both work ports on the swing valve?
DannyNewmanL48
Kubota L48
Apr 29, 2026
Harlem, GA
Not sure how testing
All of the valves share.a common return. Do you get flow our of both work ports on the swing cylinder?
Correct. I get full system pressure on both work ports when I operate the swing spool, either direction, doesn’t matter. No return.
I can put everything back to original configuration and it will still act the exact same way I described. I haven’t swapped anything without knowing exactly what should happen. And the desired outcome never happened. The passages for all of these valves are identical and can trade positions no issue. Regardless, it does not matter which way anything is assembled, the valve that is being fed by the swing pump, placed downstream of the mid inlet, never gets return regardless.
7,323
The valves have the same bodies but they are not identical. Put things back as original and we will do a different test.
#40Fan
643
479
Can you post some pics of the hoses running to the swing cylinders?
BTW, you can test the flow using air if you don't want to risk ruining a pump.
7,323
I see where you are going. The swing is two opposed DA cylinders and if plumbed incorrectly will deadhead each other. That is really basic and would explain everything. Easy to check.
