STRANGE Hydraulic Issues on L48/BT1100
DannyNewmanL48
Kubota L48
Apr 29, 2026
Harlem, GA
I checked swing cylinder hose routing probably 5 times and it matches the Kubota diagrams to a tee. There are no issues there.
Yes, each time I have taken the valve stack apart I ensured that the load checks and their springs were in place and correctly oriented. Right now, I have the valve stack disassembled again, and I’m looking closely at all of the passages inside the mid inlet to make sure everything looks correct. I REALLY do not want to pull this valve stack off the hoe again after I reinstall it. I’ve had this thing apart way too many times trying different configurations. But hey, at least my muddled incoherent swapping did confirm that the swing spool valve isn’t bad, the overload relief valves aren’t bad, and the issue is not specific to one cylinder. :)
And here’s the truth: with the lack of casting numbers or Husco identification numbers provided by Kubota in their literature, I have no way of definitively knowing what valve is supposed to be where. Husco doesn’t stamp a Kubota part number on these valves and Kubota doesn’t give you the Husco numbers either. All I know is the configuration that everything was in when I first brought it home. Someone has been in here before as you know, how do we know they reassembled it the right way? How do we know they replaced that one spool with the correct part? Sure it looks right, but is it made to the right spec? Kubota and Husco give us no way to know… They just want you to fork over $3,400 for a new set of valves.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,098
2,526
WestTn/NoMs
Danny, humor me. While you have the valve disconnected put the swing hoses in the catch bucket. Then, by hand, push the boom to one side. Does fluid come out of one hose? Then push the boom all the way to the other side; does fluid come out of the other hose?
7,443
There is no mysterious Kubota specificatiion. Your problem is in the swing circuit and thats where you should be looking for your problem. Test the external operation before taking valves apart. You bought a hoe with a checkered past and I appreciate your frustration but rants arent going to fix anything.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,098
2,526
WestTn/NoMs
There are other possibilities besides wrong connections. You gave the facebook group a week to shotgun it (with a couple of possibilities). There's more expertise here, I'm not including myself, and we'll get you going if you'll work our system.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
594
259
CNY
As stated STOP messing withe the control valve. The other circuits have nothing to do with the swing function. The only commonality is that the return from all circuits to tank merges before leaving the valve. Everything you need to diagnose this issue is in the schematic that @whitetiger posted which should be in the WSM that you have.
If the couplers were the issue the pump should be running over relief all the time. Is this the case?
What Dan asked above is a decent test. But also check that flow is present for alternating hoses when left and right swing function is actuated.
7,443
I will add one more step to @ruger1980 's test.
After verifying you are getting alternating flow connect just one swing cylinder hose and see if the boom will swing in that direction.
L35
Jun 13, 2010
733
844
CT
Don’t be one! Trust the process!
5,668
11,454
Reel it in folks.
Danny some people are just trying to give you the best help that they can.
And others are well trying to lighten the situation up.
Please do not delete an active thread, it will help you or others down the line.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,098
2,526
WestTn/NoMs
Danny, if you're still there, do this:
Disconnect the swing cylinder rod ends from the swing frame. Remove the keeper bolts and knock the pins out. You may need some kind of prop so the rods are free to extend without hitting anything.
Then start the tractor and try to swing left. What does each rod do? Swing right, what does each rod do?
