Steering knuckle Seal
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
So in going through the maintenance logs of my L2850, I noticed that the Dealer had replaced the bearings and seals in the front axle. However, the left steering knuckle is leaking like crazy and Messick’s wants $72+ for one seal! I’ve found that going to a bearing house usually saves a lot of $ over the dealer prices. Any one know the dimensions ( in mm) or manufacturers numbers of those seals? Kubota Part numbers vary, but the latest appears to be 32330-99600.
xsnrg
L2850 with BF500 loader
Mar 27, 2023
19
Ringgold, VA
Hello, what did you find out? Did you ever end up tearing down the knuckles and replacing the seals and/or bearings? Mine are leaking also. I filled the front axle housing to full on the dipstick last fall and when I checked today it was bone dry again. Looking for any kind of information before I tear into this job.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
Found out nothing, I’m going to have to tear it down and get the numbers off the bearings and seals. Not going to happen until at least fall since I need to use it over the summer.
Fedup
347
141
Winchester
You're going to wait until fall because you figure it would take you all summer to put a couple of seals in?
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
No because I'm using the tractor this summer, I just refill the axle as needed. Once apart it will take at least a couple weeks to get the parts.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
Then why are you asking me? Go order the parts from Kubota and do it! Be sure to ask them for some Vaseline when you get bent over!
Gus1957
M6800, L2501 TLB, BX2370
Dec 17, 2023
81
75
Cobleskill NY
How about trying Lucas Hub Stops Leaks? Worth a try to slow it down even.
Loadlock54
L3130
May 7, 2025
Salem, Oregon
I wonder if some silicone paste or something else might help with pitting on the housing mating surface?? $ 460.00 for a new housing is a bit rich for me...
