starting problems with B2150
11,188
Had bought new starter that had a white wire coming off of it and said damn, wrong starter, so took original too have it rebuilt. Reinstalled original starter.
What happens when you jump the solenoid?
mrmcmaple
Kubota B2150
Mar 17, 2024
11
Hebron CT USA
haven't jumped it yet St. Paddys day and festivities have begun will do 1st thing in am after 2 log truck deliveries of firewoood! Thanks for your help, it means alot!
btw do iI start with heating up glow plugs and leave key in on position when i jump solenoid
Hkb82
Nov 17, 2021
418
330
Ontario Canada
This one is an odd one. Maybe I’m missing something but I have gone over a few times and still didn’t see anything about testing your original battery. You had the starter rebuilt before confirming it was even the issue. Did you test the rebuild one before installing it? Are the fuses all good that folks mentioned? Including the ones by the battery. Gotta start with the basics. Maybe you have already done this but don’t post that info? Makes me think you changed the starter without checking the fuses. Maybe you didn’t but beats me as the reader.
ps your allowed to have a couple beers while working on your tractor.
BX23-S,57 A-C D-14,
6,320
hmm, re read the posts....
it sounds like bad battery. he did 'recharge' it...though not tested .
age,weather, use have a lot to do with battery condition.
if tractor's 5 years or older.....could very well be battery.
the 'dim' lights is pointing to 'bad' battery.
be easy to remove that battery and use jumpers to car or truck battery.
do NOT 'jump' with the original battery connected though
