YesSomewhere there is a hot on that circuit ..... touching ground.
See if Any wires on that circuit have been ....chewed .... or pinched.
It pops the fuse when the key is turned?
all accessories are off and I pulled dash apart to check wire on switchSomewhere there is a hot on that circuit ..... touching ground.
I’m not sure what I did to fix it , I moved every wire that I could check. The only wire I couldn’t get too was the fuel sending harness that was under cab. It looks like a good spot for a rat to chew on my wiring.Instead of burning up fuses, wire in a small 12v lightbulb inplace of the fuse. In this way, you can troubleshoot all you need to find the problem. (If light is on BRIGHT, there is a short)
This is why I save all the bulbs I replace in my vehicles. Different wattage bulbs are suitable for troubleshooting different fuse values.
Usually:
- a headlight bulb is good for larger fuse values (>15Amp)
- a marker lamp bulb is better for low fuse values (<5Amp)
It sounds to me as if you have a bare wire which was rubbing on the frame. Moving the wires around temporarily corrected the problem.I’m not sure what I did to fix it , I moved every wire that I could check. The only wire I couldn’t get too was the fuel sending harness that was under cab. It looks like a good spot for a rat to chew on my wiring.
