Speaking of abuse.....
5,667
OK so 5 beans for the case and lots of naughty words, thats not cheap, but better than a new tractor I guess
4,238
I had not considered welding IN the tapered-hole. I’d grind a notch along the break and on the vertical-edges of the break…and weld That Area…. not the hole itself. (but, as I’ve already admitted…I’m not a Real Welder…. I just burn rods and wire with a degree of ignorance.)
snoeproe
BX23s
Feb 19, 2026
15
It can be welded. A skilled welder can get it done.
It appears to have hammer marks on the tie rods? Maybe heat marks from a torch?
makes me wonder.
7,323
makes me wonder. I would no
Of course it can be welded. But can even a "skilled welder" do it without distorting the self locking taper in that hole or leaving a void thst will spread when the taper is tightened? I think thats going to be a real challenge without some way to ream the hole after welding. Just how much money are you going to save trying to glue it back together and how confident are you of the result?
And yeah - I think someone probably broke it trying to separate that taper :devilish:
biketopia
Feb 15, 2024
437
469
Warrenton VA
Weld it, ream it, hope it holds together :ROFLMAO: . Next time, don't hit it so hard when trying to remove the tie-rod.
4,238
AutoZone will loan the correct tools for Tie Rod removals
