Speaking of abuse.....
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,342
863
under a rock
Found this on the intercontinental web....
superglue / gorilla glue or JB weld ?
:devilish:
Trash Panda
L2501
Feb 18, 2022
287
270
Wyoming
I’m sure Belzona makes some absurd product that might be able to glue it back together successfully. For a little while. Maybe.
Im also sure that said Belzona product will cost more than a new knuckle.
lynnmor
B2601-1
May 3, 2021
1,814
1,620
Red Lion
Super Glue it and then drill & tap for bolts on either side of the hole. Drive slow after that. :whistle:
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,213
1,832
Pittsburgh
Two zip ties will have that machine prowling the manicured lawn in no time.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,475
667
Richmond, Virginia
We used to use a length of clothseline. Tie one end to each hub. For power steering, put about five turns from each side around the drive shaft, tighten up in the side you want, it'll be like a capstan on a ship. Trust me.
4,235
I actually HAVE successfully MIG welded such things. I was ignorant of all the advice it “cant’ be done” …. and “won’t last” …. and I am not a real welder….. So, I welded it out of stupidity….and operated that tractor another ten years before letting it go to the next ignorant owner 5 yrs ago who is using it still to this day.
(Cast-steel is not as troublesome as cast-iron and can be successfully-welded if pre-heated. One method is to run a bead in an adjacent, but unimportant area on the part first…. the heat will “soak” the area of the part to Actually be welded.)
Trash Panda
L2501
Feb 18, 2022
287
270
Wyoming
Recreating the proper taper in that particular break is far more problematic than welding the break would be.
11,181
Fun fact, you can take a carbon water filter element (like a refrigerator) make a taper part on the lathe and use that to keep the weld out of the taper.
I've done it several times on parts broken across a hole.
Workerbee
Zd21
Mar 1, 2020
382
266
MN
Brass can be used too to keep weld out of the taper
