Snowblower/log splitter engine swap
SAR Tracker
Nov 17, 2020
246
364
Central Oregon
Snowblower - 10hp, electric and recoil start
Splitter - 6hp, recoil start only.
Assuming the hydraulic pump will match up to the bigger engine, any down side to moving to the bigger engine from the recoil start engine?
RMS
Sep 26, 2021
275
600
Buckfield Maine
Snowblower engines do not typically have an air filter on them so you would need to do something for a filter.
SAR Tracker
Nov 17, 2020
246
364
Central Oregon
Good points - I'll check the shaft of the engine and the shaft of the hyd pump. May need a new coupling. Fitting an air filter should not be a problem, I'd think.
5,795
if it's a 'normal' engine, it should have 'mounting' for air cleaner, just lookup a 'regular' engine, same make/model.....
if the coupling is a 'Lovejoy type', only need engine side......$10 ?
3,023
1,134
You can buy a 6.5HP Predator engine new at Harbor Freight starting at $149.99. If you have to buy stuff to modify the snow blower engine, you might be just as well to buy the new Predator engine.
5,795
hmm.. most(99.44%) of all 'snowblower engines will have 120VAC (line voltage) electric starters. Fine if you're near the garage, might need a looooooong extention cord back in the bush ?
