Snowblower/log splitter engine swap
SAR Tracker
Nov 17, 2020
232
332
Central Oregon
Snowblower - 10hp, electric and recoil start
Splitter - 6hp, recoil start only.
Assuming the hydraulic pump will match up to the bigger engine, any down side to moving to the bigger engine from the recoil start engine?
5,521
Odds are ...... 'snowblower' engine doesn't have an air filter on it
Also most SB engines have 7/8" shafts on them....
RMS
LX2610HSDC, RCR1260, PFL1242, LX2963, RB1684, WC-68,Flail Mower,Grapple, Z421
Sep 26, 2021
246
478
Buckfield Maine
Snowblower engines do not typically have an air filter on them so you would need to do something for a filter.
SAR Tracker
Nov 17, 2020
232
332
Central Oregon
Good points - I'll check the shaft of the engine and the shaft of the hyd pump. May need a new coupling. Fitting an air filter should not be a problem, I'd think.
5,521
if it's a 'normal' engine, it should have 'mounting' for air cleaner, just lookup a 'regular' engine, same make/model.....
if the coupling is a 'Lovejoy type', only need engine side......$10 ?
2,856
949
You can buy a 6.5HP Predator engine new at Harbor Freight starting at $149.99. If you have to buy stuff to modify the snow blower engine, you might be just as well to buy the new Predator engine.
5,521
hmm.. most(99.44%) of all 'snowblower engines will have 120VAC (line voltage) electric starters. Fine if you're near the garage, might need a looooooong extention cord back in the bush ?
