Smart guys
2,825
Guys I need some ideas on how to fill the gaps between concrete slabs in front of the garage. When they were poured they had what I think was celotex spacers between each pour. And yes they are all gone the grass has eaten them. Soo I need some ideas how to fill the gaps maybe 1/2 inch wide
4,392
Hey Skeets, fill them with salt. Then the grass won't grow!:D
Go to your Home Depot and look up concrete crack sealer. Get it in a bucket, or caulking tubes.
CaveCreekRay
Jul 11, 2014
2,631
Cave Creek, AZ
Len beat me to it!
I used foam seam filler, punched it down an inch and then shot the cheapest silicone tubes I could find. Took a few but I washed out the crack with a hose and let it dry a couple of days before foaming and caulking. I brushed it off with a small brush to get rid of particles and the silicone bonded well to the stem wall and the concrete drive. The silicone has yellowed a tad but not bad. Doing a great job of keeping the rain out.
1,003
I did a similar thing as above. Clean out as much debris as you can. Be careful since there may be old rusted nails sticking out of the concrete into the crack. Wash out with a jet nozzle on end of the hose and let dry.
I bought backer rod and some black plastic low pressure irrigation tube. Installed the black tube across the drive to use for wireway or irrigation in future (installed caps on ends). Then installed the foam backer rod as needed to limit how much sealant was used.
If the crack is fairly level I recommend self leveling sealant from Sika. It comes in various colors and some are more expensive than others for some reason. It comes in tubes like caulking and you can pump it into the crack. I recommend leaving it a bit lower than the top or it will flow over and create other problems. It looks better if it is about an eighth to quarter inch low.
Cover it with tape or paper until it cures or junk will get stuck on it.
I used plumbers putty to seal the ends of the crack before I filled the crack.
If they are not level cracks I believe they make thicker material and then you have to tool it to be smooth. Look at brick buildings and then vertical expansion joints or window to brick joint for example.
hope to float
L3450
Feb 18, 2018
467
60
Ireland
Can you still get solid tar/pitch? You know the stuff you have to melt in a galvanised bucket over a fire. That's what I'd use. No need for any packing material, just pour it in.
2,825
LOL @ cat,, no I had no idea what to do,, Does that filler expand or what in the expansion joints? Thanks guys :D
1,003
No the Sika sealant is not expanding
2,234
Back in the late '60s early '70s, local block/brick/cement/mortar dealers sold a thin replacement board heavily wrapped with saran wrap. You cleaned out the old board, unwrapped this new stuff, dropped it in, and watered it. It then expanded to fill the joint better than the original. It was great stuff, but no one today has heard of it.
CaveCreekRay
Jul 11, 2014
2,631
Cave Creek, AZ
Bill,
That's because you are making it up.
(Why has all the good stuff disappeared? Remember when they trued tires? Lol...)
seanbarr
B7100DT (sold) - Branson 3520H
Feb 1, 2013
384
Deer Park, WA
Glad to see these suggestions, I have a few missing expansion joints to fix/fill. [emoji1303]
Luckystars
M5950 M1840A RTV900 CLUB CAR CARRY ALL 1
Mar 1, 2018
98
Webster FL USA
self leveler is what I'd use. It's what they use in warehouses to fill cracks and holes where solid tire forklifts run 100's of times a day. I think it's 8500 psi compared to regular 2500-3000 we use for driveways. It's pricey so you may want to pack the seams with a crushed lime rock or road base first. Leave just a 1" to fill.
Plan be would be use 1x P.T. to fill the voids. Ground contact of course not the blue stuff for indoor use.
SidecarFlip
Banned
548
Sounds a lot like how my wife makes soda biscuits.:eek:
