Serivice cost????
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I'm not sure about the amount of oil your tractor will hold so it's hard to give a price. As far as what needs changed it needs all the fluids and filters changed.
Engine oil and filter, fuel filters, clean or replace air filter, drain trans/hyd and change filters, front axle and hubs
My L 3000 with backhoe basic cost is, $750. This is the cost includes the oil in the engine, trans, front end, backhoe and the filters.
M 9000 cost around $900
The final cost will depend on the brand of oil and filters you choose to use. It can be done much cheaper than this but I feel it's worth the money to use the best quality lubricants to protect my investment. Not even counting the added wear protection I gain back enough fuel economy to more than justify the oil cost.
dixiefloater
L45TL backhoe
Mar 20, 2011
Slapout Alabama
Thanks bulldog....I got charged 431.00...They changed all filters and changed engine oil & hyd oil...I thought it was kinda high......Just wanted to reassure myself:)
Bulldog
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I use Amsoil in everything which is very high. Like I said I don't know the capacity of your tractor but my 3000 and backhoe hold about 20 gallons of oil. It don't take long to get expensive when you are going thru that much oil.
I would think if you took it to the dealer they changed the front axle also but if you don't know for sure it would pay you to make sure they did. At the 50hr service the oil in there is very dirty. It's almost scary the amount of metal flakes in it. If it wasn't changed that should be done ASAP.
dixiefloater
L45TL backhoe
Mar 20, 2011
Slapout Alabama
I dont think they changed my front axle oil.....my reciept doesnt show it or any gear oil being used.....Ill look at it, thats something I can do......Preciate the tip....and thanks again Bulldog
Bulldog
Mar 30, 2010
5,434
78
Rocky Face, Georgia
Just wanted to make you aware of it. If your tractor is like mine it can use SUDT in the axle or gear lube. They are not hard to change and it will be easy to do this yourself.
