I just bought a slightly used RCC42 42" rotary cutter that I plan on using in the wooded parts of my property with my Bx. Cleaned everything up and replaced the oil in the gear box. The rubber deflector on the front end of the unit was pretty worn so I replaced it.
I used the mower for about 2 hours this past Saturday. It does a great job and is small enough to back in between trees. When I was finished, I noticed the rubber deflector was already worn by at least 1" in the center. I WAS going over a lot of saplings, and I'm sure some were larger than 1".
Do the deflectors need to be replaced every few hours (they are cheap), or should I just keep using it as it is? I may invest in chains, but for now, I'll prob just stay with the rubber. Am I doing something wrong, or is this natural for these cutters?
Thanks
Thanks
