Rubber deflector on Woods RCC42
jdt81
Bx2670, FEL, MMM, Woods rotary
Apr 26, 2018
12
Landenberg, PA
I just bought a slightly used RCC42 42" rotary cutter that I plan on using in the wooded parts of my property with my Bx. Cleaned everything up and replaced the oil in the gear box. The rubber deflector on the front end of the unit was pretty worn so I replaced it.
I used the mower for about 2 hours this past Saturday. It does a great job and is small enough to back in between trees. When I was finished, I noticed the rubber deflector was already worn by at least 1" in the center. I WAS going over a lot of saplings, and I'm sure some were larger than 1".
Do the deflectors need to be replaced every few hours (they are cheap), or should I just keep using it as it is? I may invest in chains, but for now, I'll prob just stay with the rubber. Am I doing something wrong, or is this natural for these cutters?
Thanks
mickeyd
Mar 21, 2014
1,192
Guin, AL
That is natural for rubber.I used to replace mine every year. The chains cost more because they last longer.
SidecarFlip
Banned
555
My first Landpride had the rubber and I too was replacing it yearly. My new one (last year) Landpride bat wing has chains. Look like new. Chains initially cost more but longevity is 20 times the rubber.
5,594
Make you own up out of some baler belting. Get some from a local farmer who upgraded his belts, or you can buy new at any farm supply store.
That stuff also make for good striping on a yard with a finish mower.
SidecarFlip
Banned
555
Never did that, don't want to. Bad enough mowing the grass as it is.
5,594
Flip, it takes no more time. Just make your yard look like you have some pride in it. And it let's your neighbors know you're alive and well and still care to be on a machine that's not in a hospital!!
I have a friend who lives in town by himself, never goes outside to even shovel the snow this winter. Went to the store about every two weeks for some groceries. His neighbors come over and see if he answers the door, just make sure odors are not building up inside! When he told me that, I suggested he get out more....just evidence of life.
SidecarFlip
Banned
555
I have old bailer belts in the barn, might cut one and give it a try anyway. Been thinking about adding one to the top of the county plow anyaway as a deflector.
