Ed,
It's been a while but I'm back at my RTV again and looking over your information about the servo and reading the manual.
We've adjusted the 'servo regulator screw' the one pictured here in my post, but never touched the 'servo screw' the one you mentioned. After reading the manual for the 10th time, just realizing there are two servos mentioned and one is actually called the servo regulator. I never noticed.
Perhaps that is why my 1100 has always been difficult to shift. I've been concentrating on the wrong servo screw.
The manual says I should have two pressure gauges and set the pressure the same on P1/P2 to get a good neutral. But you are suggesting just do this by watching for tire rotation. Sounds like your method is simpler and just as accurate. Is this what you found and is the reason I don't need the gauges to get the same results.
And what about the one I've been playing with. After doing the neutral adjustment on the 'servo screw', what do I use as a guide to adjusting the 'servo regulator screw'.
I've made sure I have full throttle and have checked and adjusted the brake operated hst pressure release lever to be sure it is not partially activated by setting the spring tension so it is just loose on the lever and that's all. So no problems there.
You didn't notice but I have a turbo installed. See the funny ex pipe in one of my pictures.
Big difference in power. And the instructions that came with it said to add 2 washers behind the 27mm cap back at the pump to increase working pressures but don't have a gauge yet and not sure what the pressures actually are. The other trick was to remove the orifice, 2mm allen wrench, in behind the servo screw you are talking about, which must
be the biggest reason for lazy take offs because after drilling that out, because it was so tight the wrench rounded the hex in two tries and couldn't be removed, it rolls twice a freely. Really noticed that difference right away. And when the boost builds away she goes.
So you see I'm still trying to learn about this hst stuff and will not give up.
Have a EGT gauge coming so I can monitor the turbo results and fine tune that part. Of the three settings for the High speed they gave me, I'm at the middle and find in colder weather I've lost some top speed, the rest seems okay, but hoping the gauge will tell me what's going on. I have the high air intake kit and that may affect air flow to the turbo so adjusts might be required for my setup. Also would like to get some fuel economy back as it seems too thirsty for the gain, but if the EGT numbers are good I'm also fine with that. The other adjustment was for mid-range and they only had one setting, which I used, but again, hope the EGT will help me fine tune.
I let you know the results for sure.
Interested in hearing what you think and the adjustment on the servo reg. screw.
