RTV stuck in gear?
herne19d
RTV 1140 CPX
Feb 1, 2025
Chester County, PA
I have a RTV 1140 and it seems like it's stuck in gear. The rear wheels won't turn, the engine runs, but the machine won't move. Front wheels are free. Any ideas?
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,017
835
canada
Does the gear selector move ? Will the engine rev up when you step on the throttle ?
Nicksacco
Sep 15, 2021
698
412
Bahama, NC
The RTV1140 has a hydraulic pressure release activated when you step on the brake.
Its on the very back and right side of the transmission under the hydraulic filter.
Could be the thing is out of adjustment or stuck.
Also check all linkages and cables (including up front thru to the back) for rust and crud making it difficult To move. Make sure things are lubricated.
There are adjustment processes in the service manual.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,017
835
canada
If you put it in 4 wheel drive will it move ? Something may have broken in the rear end, but if it is in 4x4 the front end will move the machine.
lugbolt
ZG127S-54
Oct 15, 2015
5,397
2,094
Mid, South, USA
have an assistant watch the linkage on top of the transmission while you shift the gear selector between all ranges. Is everything moving? If so, have your assistant watch the rear axles while you start the engine and try to drive. If the rear axles turn and the wheels don't, the hub(s) splines are gone which wouldn't suprise me any.
herne19d
RTV 1140 CPX
Feb 1, 2025
Chester County, PA
No, the front end won't go into gear. It does roll free
Yes,it moves and the engine revs normally.
