How does a land pride 2060 compare to a Rhino 160? Is slip clutch the best? How about a Rhino 260 compared to Land pride 2060. Thanks for advice. I will be mowing some brushy acres,
Quote of the day!!!keeps in undercover.
Well, if you don't do the maintenance seasonally and it freezes up, it's worse than a shear bolt as it will take out the gearbox. Yes, I thought it was overly harsh too but can you risk the gearbox and Landpride asking "did you do the maintenance and check the clutch each time before you used it?".This procedure, "according to the manual needs to be adjusted at least seasonally", is overkill for anyone who uses a mower much at all and keeps in undercover. Kind of like check the air in you automobile tires and oil in engine every time you fill up with gas.
