Can anyone recommend a brand/model of log splitter that would work well on the back of my 15 HP B6200 with 12.5 HP PTO?
Thanks. Peter
Thanks. Peter
You're right to an extent, but you can use your tractor to tow your independantly driven 27 ton horizontal/vertical splitter to the wood, unhitch it and start splitting. Meanwhile you have the tractor avialable to move logs around or to do whatever you want with it. You don't have tractor if its tied up as the splitters prime mover. Unless you're doing extensive off roading with your tractor, the tow behind splitter is going to go just about everwhere that the tractor is going to go, within reason. If you ever get to use a horizontal/vertical splitter in the vertical position, then you will never go back to the horizontal. Add to the above points the fact the the three-point splitters are a lot more expensive and it just isn't making sense in my mind.It really depends how you want to use it. Do you want to take the spliltter to the wood, or drag the wood to the splitter?
Just for the sake of argument, I think a splitter running a PTO pump could work very well. I have a PTO pump running my backhoe, and the tractor engine just hums along, never bogs in the slightest even when the relief squeals on the backhoe hydraulics. Yes, it's hours on the meter, but for the most part it's under very little load.
I plan on building a PTO pump driven splitter for mine one of these days if I don't find a PTO screw type first. I missed one of those on Craig's List a few months ago and I'm still pissed about it.
I have one of them, factory made from the 70's. I had to design a screw for it, and had a machine shop make it for me.I plan on building a PTO pump driven splitter for mine one of these days if I don't find a PTO screw type first. I missed one of those on Craig's List a few months ago and I'm still pissed about it.
