lerxstland
MX5400 , New Holland 4630, LP BoxBlade, land plane, Grapple, rake, rear blade,
Have OEM rear remotes installed by Kubota dealer. Currently installing my Top n' tilt but when trying to connect the hoses to the rear remote fittings, it seems as if the sleeve on the hydraulic line at the remote needs to be slid backwards such that you can then insert the line coming from the top cylinder (or the other lines as well). Is there a trick to getting that sleeve to retract so that I can insert the hydraulic line? It seems the only way is to push on the back side of the rear remote line but I'm guessing I'm doing something stupid...any suggestions?
Thanks!
Thanks!
