I would like to install a rear remote(s) on my L5030. I want one mainly for a hyd upper link. Are there "kits" available to buy and if more than one which one would you install?
FirI would like to install a rear remote(s) on my L5030. I want one mainly for a hyd upper link. Are there "kits" available to buy and if more than one which one would you install?
1st question cab or open station?I would like to install a rear remote(s) on my L5030. I want one mainly for a hyd upper link. Are there "kits" available to buy and if more than one which one would you install?
![20210912_190954[1].jpg 20210912_190954[1].jpg](https://www.orangetractortalks.com/forums/data/attachments/88/88463-1a2ff4f67ee55ead30bd9d2ada15e3d8.jpg)
Sorry, my bad. I have a cab. I like the "whole lot less" option. If you do post kits where would i look for them? If I know what parts are needed and few very simple instructions I can do the install.Fir
Up to 3 factory remotes were available for those machines. Assuming the factory kits are still available expect to spend ~$1500 to put the first valve on the tractor. and another $500+ for each additional valve.
Your tractor has a very simple hydraulic outlet block on the ride underside of the floor boards and you can easily plumb in an inexpensive off the shelf control valve andit's some rear remote couplers for a whole lot less. Your main challenge is deciding on a spot to mount the valve and how many sets of outlets you want and where they are going to mount. Once that is done its just some simple plumbing with hoses. The hoses and couplers will be the bulk of the cost.
This question is coming up almost daily and I may just put together some simple "kits".
Cab complicates things a little bit but probably not a lot. PM me and we csn talk about specifics.Sorry, my bad. I have a cab. I like the "whole lot less" option. If you do post kits where would i look for them? If I know what parts are needed and few very simple instructions I can do the install.
That looks like front end loader remotes? Or have you tapped the FEL to provide flow back to the rear? Is that a good option, or better to use the power beyond and do an install independent of the FEL flow?Heres what I did. A simple and I do mean simple addon valve. It works exactly like factory remotes. This is a single spool valve but you can add additional spools and outlets using the exact same plumbing. Tractor side plumbing supply and return does not change - just more hoses going to the rear. I am in the process of doing a two spool kit for customer with a little older tractor.
The AUX valve was inserted in the tank and power beyond circuits coming off the loader valve and operates independently of the loader. Its exactly the same circuits as factory rear remotes. The only difference is the AUX valve is mounted right next to the loader valve rather than under the seat.That looks like front end loader remotes? Or have you tapped the FEL to provide flow back to the rear? Is that a good option, or better to use the power beyond and do an install independent of the FEL flow?
There is most definitly a power beyond port on the LA853 loader valve. Who told you there wasn't? Hose number 190 in the diagram is PB from loader valve back to tractor outlet block. Thats were you tap in.I know this is a very old thread, but I have the same problem. I am trying to add 2 rear remotes to my L5030HSTC and nobody has a kit for it. I can't even get something from the dealer. Has anyone successfully done this modification? The cab seems to knock out most of the kits, there apparently is no PB port on the loader valve, or nobody has published a way to hook up to this and get around the cab. Long and Superior have the solenoid valves but the pressure and tank hook up seem to be the problem.
Thank you so much Dan! I really appreciate it. I am bringing the tractor back down from my property next week and I will make sure it matches this diagram and get parts on order. I guess the only real issue would be running the hoses under the tractor to the valves in the back. If I come up with a good way to route the hoses I will make a post about it to help the other guys with Cabs.There is most definitly a power beyond port on the LA853 loader valve. Who told you there wasn't? Hose number 190 in the diagram is PB from loader valve back to tractor outlet block. Thats were you tap in.
Hooking up the Long or Summit electric kits is just like I described above. Repkace or extend that hose and run it to inlet port on AUX valve manifold. Run a new hose from outlet port on the manifold back to the tractor oitlet block. Wire up your controls and you are done. Thats all there is to it.
The base kit for OEM remotes is WG L8305. Messicks says they have 3 in stock. Might want to call sales (not parts) and talk to themThank you so much Dan! I really appreciate it. I am bringing the tractor back down from my property next week and I will make sure it matches this diagram and get parts on order. I guess the only real issue would be running the hoses under the tractor to the valves in the back. If I come up with a good way to route the hoses I will make a post about it to help the other guys with Cabs.
