Rear axle broke right inside cover
smallfarmer
12
Clayton, WI
I am looking for any thoughts advice on why my rear axle would have broke right inside the cover, between the bearings and nut. I was plowing and I hear a crack and then the tractor would not move forward. At first I thought it was a transmission problem but I tried locking the differential and then I could move forward. I got out and saw the right wheel at the axle seal was leaking.
So took off the whole wheel / assembly and yep, it broke just about an inch inside the axle hub. Lucky to not have been under or in the tractor when it fell. As it was, we had it jacked up when we took off the tire and it was just shocking to see how little of the axle shaft was holding it up...
Any thoughts on why that would happen? My tractor is a 1979 M4000. Thanks.
ETRon
M6040
Aug 4, 2010
128
Tellico Plains, TN
Age and metal fatigue are what comes to mind. Just outside the bearings is the highest stress point (IMHO). After 34 years or so, if it's been worked hard I'm not sure you can hardly fault it. Should be able to find a replacement in a tractor graveyard.
hodge
Nov 19, 2010
2,958
528
Love, VA
X2. Age, fatigue, and how many different people have used the tractor in those years? Not everyone respects machinery and drives it accordingly. Some people could break an anvil with a rubber mallet- who knows how they treated your tractor? I'm not accusing, just generalizing. 34 years is a lot of time and use- the older a piece of equipment gets, the more likely it is that something will break.
you might try West Kentucky Tractor Parts (wkytpstore.com) they have a tractor graveyard.
olthumpa
L275
May 25, 2011
1,501
Maine
I have had good luck getting scarce parts from them.
Good luck!
targabill
Kubota
Sep 24, 2025
This is actually a Design FLAW by Kubota, how they attached th hub actually weakened the Axle by like 75%. Class action in the works.
5,742
Class action for an alleged axle design flaw in a 50 year old tractor.
Extra butter and salt on my popcorn please.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,478
2,052
WestTn/NoMs
New member, first post to wake up a 12 year dormant string. Call me in when the movie starts.
targabill
Kubota
Sep 24, 2025
My tractor is 18 years old with this break, and it's a confirmed design flaw
5,742
My tractor is only 8 years old with this break, and it's a confirmed design flaw
This thread is about a broken axle on a Kubota M4000. The last production year for that tractor was 1981.
If you have something newer you should start a new thread and identify the tractor with this "design flaw".
As far as a suit goes what do you hope to win in way of a judgement? Broken axles are not uncommon and typically replaced under warranty.
targabill
Kubota
Sep 24, 2025
The thread is title a Broken Axle which happens of several models, I was simply sharing what I have been seeing going on the Topic of Broken Axle...
It's not my suit, But i'm watching it.
Several machine shops verified it as a design flaw, But you do not have to be a mechanical engineer to see it.
5,817
Well I'm not a mechanical engineer but I'll assume 'they' are saying there's not enough 'meat' left in the axle after machining the hole ? IF so, you'd assume ALL , or most, of the tractors with that axle would have failed. So does the axle fail, that then breaks the case ? Or is the axle fine and ONLY the case broke ?
This is somewhat interesting...similar to 'can I put duals on my BX23 series tractor' threads.
3,033
1,149
What is your tractor? Most people list their tractor in their profile and post it in their post so people know what they are talking about to help them better
5,742
You said your (unidentified) machine suffered that failure did you not? Please tell us what it model and year it is, what you were doing when it broke, and what if anything Kubota did to help?
I am not taking sides but I am a technicsl sort of guy and still have serious doubts about how a third party has determined this is s basic design flaw. I am NOT a mechanical engineer and that picture tells me nothing more than it broke through that hollow section
If I were a mechanical engineer what I would have to see to declare that underdesigned is a well documented record of multiple failures and/or an FEA of that axle under expected loading. An FEA would involve material and heat treating specifications among other things and I am pretty sure thats what Kubota engineering used when they designed it.
I suspect the "machine shops" have none of that, lack the expertise to understand it if they did, and are simply speculating.
Now start a new thread with a link to the actual suit including:
  1. Claimants supporting documentation
  2. Models and model years
  3. Incidence of failures and operating conditions
  4. Expert testimony from the machine shops
  5. Kubotas response including any testimony from their experts
  6. What judgement the claimants are asking for.
Hugo Habicht
G1900
Jun 24, 2024
911
1,285
Ireland
Well, a mechanical engineer would actually see that there may be 75% of the cross section material missing but the axle is not weakened by 75%. ;)
Good luck making lawyers rich :giggle:
Hugo Habicht
G1900
Jun 24, 2024
911
1,285
Ireland
I calculated it. A mechanical engineer would see that the axle is 30.7% weaker compared to full material (bending forces, torsion calculation I leave to yourself), not considering notch effects etc. .
I trust that Kubota engineers are capable to do those basic calculations and that they had chosen material and dimensions wisely to be strong enough for this tractor.
What happens in court is a differerent story altogether though, I would consider that being more like a random process :giggle:
5,742
What happens in court is a differerent story altogether though, I would consider that more like a random process :giggle:
In this day and age these types of components are reliably designed using FEA and different combinations of geometry, materials, and loading conditions. Its not infallkble but it does not make basic mistakes.
