So I recently got an L4060 with several Land Pride implements. One being a brush hog - RCF2072. I got the optional floating top link and have leveled it and etc as instructed.
When I mow with it - it mows horrible !! It is uneven ground with higher and lower spots. When I go into a low spot it bottoms out and scalps the grass and then when I come up out of the low spot into a higher area the mower lifts up and then leaves high spots in the grass...
This can’t be how it’s supposed to mow..?? Pic below of small area mowed - the darker green patches are the high spots it left. I always used tow behinds and never had an issue - but wanted to try a 3-pt for easy maneuverability and not have to worry about tight turns like you have to with a tow behind.
Please help....thank you.
