Ramp recommendations
7,734
Plastic ramps will get it done for ya.
Drive up the ramps till the tires hit that 7” height difference, lift front axle with the loader, and drive up. You can put down chunks of 2x4 on the trailer deck where you’ll be sliding the loader if you’re worried about keeping it pristine.
Driving up using the loader to get the front tires in place would work, but unloading presents a new problem. You're dropping off that 7"....might be fun!
Trash Panda
L2501
Feb 18, 2022
299
280
Wyoming
With the size of the rear tires, the drop would be negligible by the time they cam over and drop to the ramps.
Shawn T. W
Dec 9, 2024
869
1,579
SW Missouri Ozarks
If your willing to bump up the plastic with 2X's just build the whole ramp out of 2X12's . . .
That the same video I posted here earlier ...
timsch
'49 8N, L275DT
Jun 11, 2018
172
Houston, TX
I thought about it, but by then it'd be pretty heavy. Half plastic and half wood would be a little more manageable.
Yeah, it wasn't the 1st time. I just hadn't noticed the ramp he was using when I saw it before.
5,585
Looks like he's just using the expanded metal mesh on a frame foldsup ramp to load that thing. The type of ramp I wouldn't think would be for more than an ATV or mower....
Thats the same type of ramp that I have been using for my 2501 for the past 5’ish years.
So far, so good!!! 🤞
However, I would have added a "Double Arabian" to my dismount (you know…to impress the judges;))
4,273
I don’t trust plastic ramps… and store-bought-ramps are too steep for the air-dam on many cars these days (such as the wife’s Toyota)…. So I built my own…very simple, out of left-over 2 X 8’’s and deck-screws…
(and a worn-out boat-winch-strap):
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,406
1,022
Minnesota
I did this 20 years ago. Solid. Don’t have to worry about it caving in
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
723
841
NE FL
I replaced the 5 ft angle iron ramps that came with my trailer with a set of 6 ft aluminum years ago. Mine have worked great for me and easy to carry. I did have to deburr the welding spatter with a file after getting cut up a couple of times.
I carry a couple of light jack stands to place under the rear corners when I load and unload.
