Well it's your basic L3901I need to see some pictures of the tractor and picture of the actual implements.
I studied that idea. It looks really hard to do. They are buried under a lot of stuff. It looks like a massive deconstruction project.Could you remove these spacers?
This baler was made in India. My guess is that 3-points in India are narrower than in North America?The arms on the tractor being cocked to the side, does not affect them one bit.
That baler has an extremely narrow set of arms, it's rather odd.
You need to have someone weld some brackets on it to make it work with the QA.
Yeah, that's what I've done for the last several years. The problem is that the ball joints at the ends of the lower links get twisted to the limits of their movement range, the baler is quite heavy, and it feels like they will become a point of failure. If those ball joints freeze up, then I have a big problem.OK. EASY solution..... remove the quick hitch, bailer should connect to 3PH fine.
I appreciate the ideas! That said, outside of both "spacers" are a bunch of complex moving parts. Linkages, drive chains and so on.hmm, back to plan 'b'. As OM said, remove spacer on the one side. Would that be enough of a gap ? Looks like 3 or 4 bolts, kinda easy to get to ??
