Quick Hitch? 👍 or 👎
pgmrdan
BX2380, L3902HST, Massey Harris Pony, Ford 3000, Bobcat 751 skid steer
Aug 16, 2017
201
80
Like it, hate it, or something in between?
8,242
Have every tractor and skid steer set up with them.
Love them!
6,376
I’ll be the first to say I love my QH. $80 with coupon years ago from Harbor Freight.
Added an extended hook from our OTT member Kenny at www.Boltonhooks.com - world of difference.
Bearcatrp
Mar 28, 2023
780
429
Minnesota
Once you go quick hitch, you never go back! Love mine.
Showmedata
LX3310
May 18, 2022
199
158
Boulder CO
somebody oughta say it: this is the single most frequent thread on the forum. Wouldn't take much searching to find the last 10 discussions...
6,317
I have a Speeco quick hitch that is setting on a pallet with 6 Kubota rear wheel weights that I just dug out to sell. I've had the quick hitch for several years and never had enough implements that fit it to justify messing with it.
I'm the odd one out!
3,305
I have a QH-15 from Landpride, and I like it when I use it, but since the BH is on 95% of the time, it does not get used enough.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,080
3,307
While I do like mine, the hydraulic top link seems to be a necessity. I do not have that yet. Still find myself getting off the tractor to adjust the top link to pick up the next attachment. It's still much much easier than the pins.
5,535
Don't have any, no need as the backhoe has never been off my 'lawnmower' in 6 years !
My gripe about them is that they are NOT 100% compatible with all tractors and implements. Lots of posts here about needing lower pin adapters, modifying the hook,PTO length and top link woes.
Never ever had those issues with my 4 tractors and 6 implements that use the A-C SC system.
Bmyers
May 27, 2019
3,393
4,137
Southern Illinois
I like my QH.
pgmrdan
Aug 16, 2017
201
80
Sorry.
The reason I asked is because my QH05 has been a bit of a pain but my QH16 works like a dream. Not certain why the difference.
Moose7060
Oct 14, 2023
762
1,980
bc
Love my QH16. Makes life easier.
WAS BANNED FOR NSFW PICS
5,143
In the not-too-distant past, the same discussion was about skid steer front mountings. There were a number of different designs out there and the one that worked the best was on the Bobcat machines. Since Bobcat owned the patent on their design it wasn't until one tractor company approached Bobcat to license the design for use on their tractors. They paid a royalty for each tractor that they installed it on. That opened the door for all the rest of the tractor manufacturers to also go to Bobcat and make the same deal with them. I don't know if the patent has run out or not, but if it hasn't then all the tractor companies that use it are still paying the royalty. This might be the reason that John Deere still hasn't adapted it for their tractors.
Today LandPride is only marketing their products as "Quick Hitch" ready.
Mikeymotorbikey
B2601, Case 446, JD4475
Jun 30, 2022
30
23
North Branch, Minnesota
I dislike the fact that there are compatibility issues. I'm too cheap to go purchase new equipment just so that it would be compatible with a QH.
As Jay says above, all of the issues with bushings, pins, hooks, adaptors . . .
I despise the fact that most cat 1 QHs are not really cat 1. The only 1 is the SpeeCo E-hitch, I believe.
I added hydraulic T&T and this has made implement hook ups uneventful. Having individual control of the 3 points of the 3P makes life so much easier. And, that transfers over to usability of the implement while in operation.
3,758
The B is the first one I ever used,, I mean who needs a quick hitch ,,, yeah me too!
8,121
I had a QH05 for five years and never had a problem with it or with the many BX sized implements I used. Once I moved up to MX6000s and an M6060 I also moved up to a QH10 which is great. The QH15 is a LP/Kubota $hit show with its nonsensical CAT 3 lower links, but I'll be modifying it soon to work like a QH16 which is basically a QH10 with an adjustable top hook.
A QH with top-n-tilt is the way to go. I don't believe there's an easier way of picking up and dropping off an implement short of having someone else do it for you! Don't forget, the locking levers can be in the down/locked position when you pick up an implement i.e. you don't have to raise the levers before connecting to the implement.
papajoe
L3901DT Shuttle (2017), B6100E (1978), B6100E (1979), B6100HST-E (1985), RTV500
Dec 26, 2017
96
178
Oak Grove, La.
I love mine. Lots of my equipment is home built. Some is newer store bought and QH compatable, some not. A couple of days in the shop with a cutting torch and welder has it all fitting now. That little bit of enjoyable work has saved me many hours of agonizing frustration.
