Pushing rear attachments, specifically a landscape rake?
Sporto
B2601-1, FDR1660, RTA1258, BB1560, LR1672, PFL1242, MK Martin Snow Blower
Mar 20, 2021
72
Manitoba Canada
I have the Land Pride landscape rake and it will not turn 180, but I wish it could:(, as for the tines they are spring steel so going backwards should be no issue at all. Also I pull a 60 inch finish mower which should act similar to a rotary cutter when going backwards(movement not cutting ability);) and that is one of the things I like about it
icehorse
L3901, box blade, tedder rake, mini round baler, drum mower, rotary cutter, misc
Aug 10, 2022
209
52
Yeah, I could lift the cutter before backing up. But it's a little bit like using a vacuum cleaner, there is often a natural back and forth pattern when cutting. more pondering...
mikester
M59 TLB
Oct 21, 2017
4,132
2,828
www.divergentstuff.ca
Absolutely DO NOT push attachments like a mower backwards. The wheels are only designed to turn clockwise. You need special grease for counter clockwise turning wheels.
Biker1mike
Jan 11, 2022
1,174
1,275
Gallatin, NY USA
?????? The wheels on my mower deck rotate 360 degrees and mows just fine when pushed.
I use the special grease located next to my left handed monkey wrench.
