I have a B-7300 with a small bush hog. When cutting grass, the RPM's are at max in the 540 rpm position which causes the engine to run very hot, almost pegged to red. Is is possible, or recommended, to use the 2500 rpm selection with a lower engine rpm? After about an hour mowing, this little engine is boiling hot.
Thanks for your help,
