PTO Speed
tw4929
B-7300, Grizzly 42" Bush Hog
Jun 14, 2026
NC
I have a B-7300 with a small bush hog. When cutting grass, the RPM's are at max in the 540 rpm position which causes the engine to run very hot, almost pegged to red. Is is possible, or recommended, to use the 2500 rpm selection with a lower engine rpm? After about an hour mowing, this little engine is boiling hot.
Thanks for your help,
RMS
Sep 26, 2021
316
686
Buckfield Maine
Not sure about the RPM's, but are you checking and cleaning the radiator while brush hogging? The radiators seem to clog up more during brush hogging than any other time for me. There are plenty of posts here on overheating due to clogged radiator fins and the damage that can occur.
GrumpyFarmer
5,247
I would think that machine should run all day with no issues, so long as engine room in good shape and not too much dirt/debris on the radiator fins, and fresh coolant.
when was the last full service last completed?
3,156
Changing the PTO speed range and running the engine slower will probably make the engine work harder and overheat faster due to changing the place on the power curve of the engine that it is operating at.
7,351
Thst is not a solution for multiple reasons. You have a cooling system problem. Fix it and your tractor wiill mow all day at rated engine speed.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
200
202
Before I used it again, I would be inspecting the cooling system for issues.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,373
896
under a rock
I agree.
I blow out the radiator screen every time I cut the grass with my BX
It always has clippings and dust in it. Air intake filter as well.
only take a few seconds with an air hose.
Caden
1979 B7100
Apr 16, 2026
341
193
No, that's a bad solution for a problem that should never exist in the first place.
My rad when I got my tractor was so clogged with dirt that I had to remove it and soak it in a tub of water to loosen it all up from between the fins.
Killer Bee
107
172
Show-Me State
first off, if your rear pto is a two or more speed, they're probably in the output rpm neighborhood of 540/750/1000 at wot.
1500/2500 rpm at wot are more likely specs for mid pto (belly) or front if equipped.
the kind folks here can lead you to operators and maintenance manuals if you ask.
secondly, you should never run an implement over it's rated rpm, follow manufacturers specs. over speeding rotary equipment is not good.
as mentioned, running your machine at same or similar load at lower rpm is also not good. most diesel tractors are designed to run at governed speed or wot (wide open throttle) at rated loads.
also mentioned, what is machine condition, specifically cooling system? besides clearing mowing debris for good air flow through radiator, how are the belts, fan, water pump, thermostat, coolant, etc.?
a handheld digital infrared thermometer is a great tool for cooling system troubleshooting. starting with a cold machine, take appropriate readings from warmup to operating temp or above to help identify the culprit(s).
how long has the machine exibited these symptoms? overheated in the past? current symptoms started suddenly, gradually, after any repairs, maintenance, or other incident?
how many hours on the machine? has is it exhibited these symptoms in the past with other implements/attachments?
how many hours (estimated, most don't have meters) or age on the brush hog? does pto turn smooth and easily by hand? no binding, popping, squealing, grinding noises?
good luck figuring it out! 🍻
11,269
540RPM is the rear PTO speed
2500RPM is the Mid PTO speed, you can't alter either one.
tw4929
Jun 14, 2026
NC
Thank you.
tw4929
Jun 14, 2026
NC
Thanks for the tips. I bought the machine used, of course. I know the fan belt doesn't look great, but still in tack. As far as the coolant, it probable should be changed. Looks like I have a project ahead.
Shawn T. W
Dec 9, 2024
846
1,549
SW Missouri Ozarks
I don't have that exact model, but most have a screen in front of the radiator which makes it easier to clean, it should slide out or up, then you can clean it.
Then you need to also look at the actual radiator, as even with the screen in place, stuff still gets by/through it and over time clog it up ...
tw4929
Jun 14, 2026
NC
Thanks for all the tips. Is there a good video on how best to drain and remove the radiator
Thanks for the tips. Is there a good video, or instructions, on how best to drain and remove the radiator? It looks like it will have to be removed to replace the belt.
tw4929
Jun 14, 2026
NC
Shawn T. W
Dec 9, 2024
846
1,549
SW Missouri Ozarks
I don't have that model, but on my Kubota there is a petcock on the right side of the radiator ... Or you could just pull the lower hose ...
If you plan on working on it ... I'd highly suggest getting the Workshop Manual (WSM) for it, I prefer the paper version even though it's more expensive ...
John D 2
Jun 6, 2023
200
202
I agree with Shawn. BEFORE you start wrenching on it, get a shop manual.
Start with the simple things first. Even a perfectly working cooling system will overheat the engine if the radiator screen is clogged and preventing air flow.
I would start there.
re54drider
L2800, FEL, Bush Hog
May 9, 2011
84
36
Goldston, nc
Like you I live in central NC. Mowing now will fill your screen and radiator with seeds and chaff. My 2800 will overheat after about 6 hours.. Don't keep mowing, stop and clean off the radiator and screen when you start getting a hot gauge reading. If your belt is needing replacement you will hear it squeal upon startup. Don't ask me how I know all this...
