How long do you guys preheat your engine blocks , ( not glow plugs) in 0 to 25 degrees f for starting? I have an f250 7.3. Sometimes it sets for a week or 2 before starting and I don't want to leave the block heater on all the time.
I have a 7.3 as well. When I want to start it and it's frigid out, I plug it in about 60 minutes before I start it.How long do you guys preheat your engine blocks , ( not glow plugs) in 0 to 25 degrees f for starting? I have an f250 7.3. Sometimes it sets for a week or 2 before starting and I don't want to leave the block heater on all the time.
Simply because a cummins in s dodge has an intake pre-heater. A shot of warm air in the intake will always pop it off..I have a 04 Dodge 5.9 Cummins, it has never ever been plugged in, even when the temps were minus 20 plus and the truck stayed out doors. Never failed to start.
Now it has failed to keep running twice when fuel gelled even with Power Service added at minus 20 plus, but that is not the trucks fault. When the temps are expected well below zero for few days I add about a gallon of Kerosene to a full tank with a dose of PS, hasn’t gelled again.
FYI, Cummins motors in Dodge trucks all have an intake pre heater.
My 1997 7.3 don't. Wish it did sometimes. I have good glo plugs and hot batteries. I don't drive the truck in the winter at all. Never seen snow in fact. It's 'hibernating ' in the garage on a tender. I start it every few weeks after a 60 minutes on the block heater if it's really cold. If not, just the glo plugs.So do a lot of the SD 7.3. My F250 has one (2003).
Only time I use the block heater is if I know I'm using the truck and it's not parked in the garage (rare). I drive the Mustang almost every day that it's not broken.
Interesting. What is the nipple for? I presume for fuel inlet, is that correct?Here's the intake heater from a Deutz 6206. I put a new one in years ago and have never used it. It's just not required. It's a direct injection air cooled engine that will start easily even after setting for months.
Some have the intake heater and some don’t, usually don’t know it doesn’t work until the glow plug harness or valve cover melts, they bad about the relays going out, the valve cover gaskets and harnesses melting, but we don’t have to worry about it much here lol,don’t know where you at but my bota and 6.0 need very little glow to start if anySo do a lot of the SD 7.3. My F250 has one (2003).
