“Practice" does not make perfect you Jackass…..Only “perfect practice” makes perfect!!!!
5,580
I would like to thank everyone!!!!:love::love::love::love:
@ken erickson , that was a great write up/explanation sir…Thank you👏👏👏
I just turned the most beautiful 12 pitch thread.
Here she is
Here she is under 6.2X magnification.
I am super stoked!!!!!!!
I followed y’alls advice and it turned out great!
First I “Un-F’d” my compound, and set it at 29.5 degrees FROM PARALLEL!!!
Then set my tool square to the work piece using the “fish-tale"
Then zero’ed everything.
Then using about .005 cuts, I slowly took some passes….Here it is as I progressed.
Now I just gotta figure out how to use these “measuring wires"
Not having a nut to test it, I am going to give these things a “whirl”.
I also forgot to address the question of "WHY I decided to try it in reverse."
It basically boiled down to me not wanting to have to worry about crashing into the head.
The way Joe Pie describes it, threading in reverse gear, sounded like a good idea….So I tried it.
I must say that I do like it, However I can see where “regular threading” with inserts would be handy…..(SO I ordered a set like @Lil Foot ;)👏)
LIVE UPDATE:
As I was typing this, Mrs. RWS opened my package of “emory thread"
ALL DRESSED UP AND READY FOR PROM BABY!!!!!!! WHOOOHOOOOOOO
Here she is under 8.2X magnification
I don't care if thats cheating or not….I like it!!!!!
(I know…I know….."calm down dumbass, you don’t even know if it fits":ROFLMAO::ROFLMAO::ROFLMAO:)
Reactions: 7 users
ken erickson
Nov 21, 2010
1,445
2,708
Waupaca Wisconsin
Got to love it when a plan comes together! Good job :)
Side note,
The main reason for the 29.5 degree compound setting rather than straight in perpendicular is to reduce the cutting tool force and "generally" will give a nicer finish with less chance of chatter especially with deeper threads. With 29.5 degrees the cutter only cuts on the leading edge angle of the 60 degree included angle of the cutter. This becomes more important on long unsupported threads and slender work pieces.
3,586
Or you could buy Thread Mikes:
Or Thread Triangles:
Oops- theres that buying thing again!
5,580
Wish I had a "money tree” 🤷‍♂️ (Or one of your famous “bin stores” near me ;) )
But in the mean-time, I’ll stick with my "Chi-Com Thread sticks"
My mill needs/needed a “Ram Lever”
and since I am a newly minted Threading King;),
I walked over to the scrap pile (that I still have not cleaned up) and looked around for a “donor"
Found this…...
Then I knocked out a 3/8-16 thread on this rod that was/were “Dead nuts” in the middle of class 2A thread specs…..
I actually had a hard time threading it in. (Had to run a tap in the hole to clean it up)
This is 12X magnification.
"Tis a thing of beauty"
Looking at my calendar, it appears that it is "International Internal Threading day"(y)(y)(y)
and since this little bad boy showed up last night…...
It’s shaping up to be a ”Hum-Dinger” of a day!!!!!!
It’s all "fun and games”, until the "tool bill" shows up and has to be paid;);)🤔:ROFLMAO:🤬
#40Fan
670
497
Now you need to put a relief at the end of the threaded section so you have a place to stop the tool when threading towards the chuck.
5,580
EDIT: No sir…..I have decided to go a different route entirely.
OK, well, things did NOT go as planned.
I crashed my lathe, not ONCE…..But F’ing TWICE……(no pics)
Threading to the lathe chuck F’ing sucks my a$$…
After I got done chastising myself for being a dumbass….TWICE…and a long protracted cursing session!!!!!!!….I went to the Big A and immediately ordered a LH Internal threading bar, so now I can thread in reverse, toward the tailstock. (just like Joe Pie says to do)
I guess there's a reason they don’t put pockets in coffins…..So whats another 80 bucks aye’ ? ;)
ken erickson
Nov 21, 2010
1,445
2,708
Waupaca Wisconsin
Interesting how experiences vary! Out of curiosity what RPM is your head stock running when you're threading? What RPM range does your lathe have?
5,580
It goes from 70 to 1400 rpm, (I think??? maybe 1600)
I was on the 70 speed when I screwed up…
ken erickson
Nov 21, 2010
1,445
2,708
Waupaca Wisconsin
Gotcha! I have had 3 different Chinese geared head lathes but did not remember the slowest speed. I think the old SouthBend lathes with back gear had about 50 RPM as the slowest speed.
Sorry about crashing and no damage! Appreciate your posts and pictures as always!
bird dogger
Feb 24, 2019
1,811
1,785
North Dakota
I'm a little late to this party and this might be considered cheating...... but South Bend has a great little booklet called "How to Run a Lathe". You can buy hard copies or find free download .pdf versions all over the internet.
It contains all the basic setups and directions for all kinds of operations and made my first thread cutting attempts turn out great. It's a super quick reference book for most all basic operations on the lathe. And it's hard to beat FREE.
But if you consult it before starting your project, it does make you feel like you're cheating!!
3,586
On the subject of crashing:
If your lathe is electrically like mine (and I suspect it is) there may be a problem to be aware of.
If you are power feeding or threading towards the headstock, and see an imminent crash approaching,
DON"T slap the spindle into reverse.
It will continue in forward and crash with enthusiasm. o_O
The spindle must come to a complete stop before reversing, or it will continue on in forward.
Don't ask me why, this Birmingham is the only machine I have ever run that does it, but I have heard the same problem exists with Shop Fox, Jet, & Enco models. (don't know about Grizzly)
It is easy to check, just use lots of room & low speed.
Don't ask me how I discovered this. ;)
3,586
May I recommend:
Yooper
3901 LA525
May 31, 2015
1,751
929
NE Wisconsin
Bill, what you experienced is unique to single phase capacitor start motors. And yes, we share the same discovery experience 😉🤣.
I believe RWS has a three phase motor running on a VFD. What I don’t know is if the VFD can handle an instant reverse. I do know you can couple a resistor with most of them for braking but I have never done this. We have some very good electrical savvy members and I would like to hear what they have to say on this.
I recently purchased several radius lathe tools (indexable) so I can stop the carriage in the groove when threading and not have a stress riser that a square cut off tool creates. I have done the threading in reverse with good results but that is a new trick for this old dog.
3,586
That makes sense, as the vast majority of machines I have run were 3 phase industrial stuff.
(y) (y) (y)
I have probably done more threading in reverse than in forward, because of running production parts in the early days.
Bosses tend to get mighty testy when you wipe out a $3000 casting because you ran into a shoulder when you didn't disengage the half nut on time.
God help you if you did it more than once.
3,586
Mostt of my stock stash sits outside in a plastic storage building.
I have a few more pieces scattered around that are too big to fit in regular stock storage.
5,580
View attachment 178705 View attachment 178706
One of my "retirement projects" is getting more organized Bill.
Although, I do have to say, I am almost convinced/(100% sure), that "organization" is/might be/probably is an "intrinsic mental thing"....
After 50+ years, I am not sure I possess such a gene???? (but I am trying;))
I love seeing your ideas though(y)(y)
torch
Jun 10, 2016
2,886
1,133
Muskoka, Ont.
Just because a nut threads on does not mean the thread fits. Undersize threads fit in the nut too, so you're right to measure the final result.
I have a set of the original precision ground Pee Dee wires from Fisher machine and also a 0-1" thread mic. The thread mic is faster, the wires are more versatile. And possibly more accurate.
In the case of the mic and a 60° imperial V-thread, simply select the correct anvils for the pitch, zero them out to each other, ensure the mic is oriented correctly with the double anvil on either side of a crest and the single anvil aligned with the root on the opposite side and use as with any standard micrometer. One "gotcha" to watch out for: the thread OD needs to be cleaned up first, especially with stringy materials and fine pitches. The double anvil has to contact the flanks of the thread, not get hung up on the OD. You can even use it to check metric 60° V-threads with the appropriate math.
But: cutting an Acme thread? A sewing machine thread with rounded root? 55° Whitworth? Multi-lead? A thread larger than your thread mic? Grab the wires. And lay a clean cloth below the work -- those wires are a PITA to find after they drop into a pile of chips. Don't Ask Me How I Know This™.
I don't know how accurately ground your Chi-com wires are. The Chinese can put out some decent stuff now. Brands like Accu-size seem to be OK quality, many more are still junk. So before relying on those wires too much, I'd recommend you check them carefully for size and concentricity. If they're off-size, out of round or tapered they're useless.
One of these days you will take it into your head to cut an internal thread. Wires and mics won't fit in there. You will first need to cut a go/no-go gauge with 3 steps: undersize, correct size and oversize. And again, you will need to be able to confidently measure each of the gauge's pitch diameters because any error in the gauge will be compounded when you measure the internal thread.
ken erickson
Nov 21, 2010
1,445
2,708
Waupaca Wisconsin
Thought of you after watching this video! Interesting gadget.
RWS, thought of you when this YouTube video popped up in my feed.
Interesting lathe gadget for sure!
watch
#40Fan
670
497
Weird....that popped up in mine a couple days ago as well. And I hadn't watched a video from him in probably 5 years.
