Post hole digger and B7100
bmbreer
Kubota B7100HSD
Apr 22, 2011
9
Westminster, MD
I am considering buying the CountryLine PHD (model 24045500) sold at TSC. Does anyone know if my B7100HST will handle this? With this SCUT is there a limit on the size of the auger I should use? Thanks.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
As long as you dig slow I think you will have plenty of power. I just wonder if a 7100 has enough lift to get the auger off the ground. Those tractors sit so low to the ground.
I bought one of the 12" augers from TSC. I can't just hit the float. The control has to be slowly feathered down to control how fast it digs. I haven't dug but a few holes with it so far but it's bad.
Kytim
B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
Aug 14, 2009
848
15
Western Ky
I'm very interested in this info as well. I need to drill several holes and my hands are no longer able to do it the old way as when I was a kid.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
I've got a standard size auger {cat 1} for the back of my B6100 and I've handeled it no problem. I think its an older Woods model, not really sure my dad gave it to me. I ran 6, 9 and 12 inch bits on mine.
Kytim
Aug 14, 2009
848
15
Western Ky
Eric, Well if your B6100 handled it there should be no reason a B7100 shouldnt handle it being as they are essentially the same tractor. thanks for the information, nothing beats knowledge!!
tim
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
I will mention is was a HUGE p.i.a when I got the 12 inch bit hung up on what I think was either a rock or China. The bit was all the way in the gound as I was trying to set a 6x6 timber. The tractor hit whatever it was in the gound and bogged out the tractor and killed the engine. I could not lift it out the ground no unscrew it loose. Had to take a pipe wrench to the PTO shaft and after almost 2 hours of turning by hand got it out.
4,046
Golly I think by that time I would be looking for a couple sticks of poweder,,, FIRE IN THE HOLE!!!
Lencho
B7100hst
Jan 21, 2017
428
101
NM
Digging up an old post here. I have a mid 90's B7100hst and want to set some fence posts. TSC has them in stock along with different diameter augers. I'd like to set 4x4 posts, roughly 2' deep. I ask the forum for advice. Thank you in advance!:)
