Plasma Cutter
bronc71
BX25D
Feb 25, 2021
57
37
North Idaho
10 years ago I bought a Hobart 12ci. I used it maybe a dozen times, and kept it stored on a shelf in my shop so it still looks like I just pulled it out of the box. I put it to good use the past few weeks working on things like making the Equal angle hitch for the mower, and a few other projects.
Last weekend I was cutting off the axle brackets on a cart with it and it quit working. Last Friday I opened up the case and found the reason is due to a burned circuit board. I contacted Hobart support and found out a replacement board cost $2,308. This unit cost me $740 brand new off the shelf and I can replace it for $650 with a newer model.
Reason for this post is not to complain, but to find out what others have for plasma cutter? Other brands, and how they held up.
I had a very similar problem on my Miller plasma cutter. Circuit board would cost about a thousand bucks. I contacted Miller to get some deeper troubleshooting information. Turned out to be a 5 dollar transistor with 20 bucks shipping On internet. I tried it and fixed it. It pulled away from a heat sink and cooked. Might be worth calling Hobart to get more technical troubleshooting information? I was very lucky.
ACDII
Oct 21, 2021
681
424
Illinois
Board is fried, being multi layer, its can't be bread boarded either. There is literally a gouge in the board between three transistors.
3,506
I bought a Forney 20P from TSC for less than $500, but Amazon will beat even that price at $450 with free shipping:
I have worked it VERY hard cutting almost 3,000 feet of 14 ga steel and it also cuts right thru 1/4” steel like it was butter. Expendables are easy to find, inexpensive, and also available online. Anyone who’s been welding/cutting metal vey long will know the name Forney:
https://www.amazon.com/Ferny-Easy-Weld-251-Plasma/dp/B078TZ9WMM/ref=asc_df_B078TZ9WMM/?tag=hyprod-20&linkCode=df0&hvadid=312096335436&hvpos=&hvnetw=g&hvrand=14865501243173873900&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1026201&hvtargid=pla-569011383329&th=1
ACDII
Oct 21, 2021
681
424
Illinois
I have to say, that Yeswelder I got is NutZ! It needs to be low amp on 120, but on 240, Holy Schiznit! It sliced through hardened bed bolts like butter. It will take practice to get a nice clean slagless cut, but handsdown 100% better than the Hobart 12CI.
I also had to get a cylinder for the welder since Flux core and thin sheet don't go together very well, too hot, burns through quickly so have to spot weld plugs and then slag builds up causing arc issues. Once I switched to .024 and 75 Argon, the welds came out great, so now have a decent welding setup, only need a Stick and TIG to complete it.
Showmedata
LX3310
May 18, 2022
202
169
Boulder CO
I'm glad your YesWelder plasma is a good unit. I got the MP200 5-in-1 machine and I'm not really thrilled with it. The primary problem is that the Tig is crap. The plasma is OK, and the mig is just OK. (haven't tried stick or flux core). It's convenient having only one box, but if the Tig had been accurately advertised on the kickstarter I would not have bought it.
WFM
L3800
Apr 5, 2013
1,492
921
Porter Maine
I have the Thermal Dynamics cutmaster 52 it has given years of service.
Cuts 1/2" , gouge to 3/4"
I did have the 1/4" version for ten years back in the 90's. Firestorm I think it was called. I sold it on Feebay for what I paid for it after ten years of use.
Made in Lebanon New Hampshire I believe.
SGT13
Bx23s, CB05 bucket, GS05 scraper, Shop made ballast, hangers, & anchor pts
Sep 2, 2021
14
12
Arizona
I have a venerable Lincoln "Procut 60". Out of production for several years now, it's getting harder to find parts and consumables. It is quite finicky about the electrode and nozzle condition and the cost of consumables is not negligible. The finish is not up to laser or waterjet standards, but is way neater, faster and far cheaper than oxy-acetelyne. Assuming you have an adequately sized air compressor and power supply, of course.
Another advantage of plasma is that you can cut anything that is electrically conductive. For fun, apply a layer of thin sheet metal or aluminium tape and you can cut non-conductive materials like glass. Not a great cut, but it will work. Best done with the metal on the back, overhanging the edge of the non-conductive material to start the arc.
That's interesting. Been using plasma for decades & never heard or thought of doing that. Now I've just gotta.
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
Get a hypertherm. They support their old tech and when something wears out you get an upgraded version most of the time. With Hobart you will buy the exact same board that will burn out again. With hypertherm they will sell you an better one and it won't be priced to force you to buy a new one.
GrappleDave
New Kubota L2501
Mar 19, 2022
37
44
jackson NY
True, Hypertherm does support some of their older machines but I think at the 20 year mark they give up supporting them. I have a year 2000 Hypertherm Powermax 900 plasma cutter and about two years ago they sent me an email telling me they would no longer support consumables for my machine. In the same email they informed me they are offering a new updated torch for my machine, I was hesitant to but it at $600 plus but I finally did and man what a difference, that and I bought a new 5hp 80 gallon two stage air compressor and tied the 80 gal tank to the 60 gal tank of my old compressor that the head seized up on. Definitely need a lot of dry air.
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
Where I used to work has a hypertherm that was made about the same time as my miller625, back around 2003-2005. They can still get parts, upgrade parts. I cant. I have to either buy old parts at crazy inflated prices or mod my machine to run new hypertherm stuff, or sell it and buy a new hypertherm.
All the other welder companies just make you buy a new machine. If I had bought a hypertherm 20 years ago I definitely would have gotten an upgrade torch.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,630
1,896
Near Lancaster, PA, USA
Late for the party, but I had a chance to get a Hypertherm 30AIR and it's served me well for the past few years. For me, it was an ideal choice. It has a built-in compressor, and operates on 120v (at a lower cutting amperage) or 240v at 30A. Power is all that's needed to run it. I have an air compressor, but no shop air setup with filter/dryers. I very rarely cut anything thicker than 1/4". The garage and tow-behind generator has both voltages available.
Orange L4310
L4310, GR2110, Deere 450b
Oct 31, 2022
Appalachia
My .02
My dad has a 10-12 year old Hypertherm. I’ve used it a bunch. Two years ago I moved away and had to buy my own plasma cutter. I bought a Lincoln tomahawk.
Neither has ever failed to function but the Lincoln cuts better/easier. Maybe newer technology makes the Lincoln better?
