Plasma cutter - desirable features
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
467
740
Baranduda, Victoria, Australia
I'm about to purchase a plasma cutter and hoping that some here who have them might be able to advise good or bad features. I'll be looking for something that can give a clean cut in 12 to 16 mild steel.
Since most here are US-based and I'm in Australia, recommending brands or models may not help. Hence the question about features.
Any advice appreciated.
11,382
You've got the plate thickness dialed in so that's going to narrow down your choices. More is better in my experience since it gives you options. Next thing is onboard air or stand alone compressor. I have a HyperTherm 380 that I've had for at least 25 years and probably longer. I run it on 220V and supply it with dry air. It will cut 1/2" plate but it's not a great experience.
You need enough air flow rate and the air needs to be dry. Other than that, there are so many brands out there now and your budget is a factor too. Do you have JASIC in Australia?
DaTow'd
what ever it takes to get the job done
Aug 13, 2013
235
223
Bella Coma BC Canada
I have a Miller Plasma Cutter best thing is the consumables are easy to find.
I have a friend that bought a EBay plasma cutter and has a hard time finding parts that fit.
16 years ago we had a flood and the water was 5 feet high on my shop floor and the plasma cutter was under water. I opened the case and found the "guts" are covered in some kind of wax - I hosed it off with fresh water and let it air dry it works like it always did.
I have a air filter for the compressed air
wonderful invention
11,382
wonderful invention
I'm in the Miller camp as well. My Millermatic 185 is still going strong more than 25 years later. I used Miller, Hobart and Lincoln welders during the 15 years that I worked as a coded welder, but Miller was by far the preferred choice on most job sites and in most fabrication shops.
I don't know enough about all of the cheap welders and plasma cutters that abound today, but I have my doubts about the duty cycle and longevity. Perhaps good enough for most small jobs and that's all that matters to many.
Paul Allwood
Jul 8, 2025
467
740
Thanks. I have a compressor so won't need an on board compressor model. I've never heard of Jasic, just googled and none of the tool suppliers near me stock them.
Paul Allwood
Jul 8, 2025
467
740
wonderful invention
Easy to find consumables is a good point - probably makes me lean towards the brands that the large local tool suppliers carry.
11,382
Ready to find consumables is a good point - probably makes me lean towards the beans that the large local to suppliers carry.
I'd want a Miller Spectrum 875 at best or a Miller Spectrum 625 at worst but they're $$$$. :giggle:
But heck, stuff from YESWELDER makes all kinds of claims and they're 1/10th of the cost. Then again, the Miller Spectrum 875 which "only" claims to cut up to 3/4" mild steel plate weighs 50lb, but the mighty YESWELDER CUT-65DS PLUS claims to cut 1" mild steel plate but it weighs less than half at 23lb. 😂
2,803
What do you mean by the “in 12 to 16 mild steel.” statement? 12 mm to 16 mm thick?
Please clarify.
11,382
Please clarify.
He's in Australia ... of course he means 12mm to 16mm. 😂 He's talking 1/2" to 5/8" plate in the US.
10,515
Give us some names that are available for you there.
You want a 60 to 70 amp minimum
You also want pilot arc as it makes starting the cut on thicker steel so much easier and cleaner.
4,918
As per normal, lots of good advice above.
I personally started off by gambling with an "Amazon/Chi-com- hand held special" for a couple hundred bucks.
“For the money”, it is a surprisingly nice little machine, and I am 100% satisfied with it, and would buy another one. I have cut 10mm’ish (3/8 inch) stuff and it did reasonably well.
That one “got me hooked”……...
My next one was/is a RazorWeld that I purchased when I bought my CNC plasma table. I have only cut up to 6mm (.250 inch) with it, but I was happy with the quality of the cut.
Full disclosure: The “main reason” I went with the Razorweld was because it was a “package deal” from the CNC table maker, so I was assured that it was designed to be compatible with the “brain” of my table. (and it’s what I could afford;))
If I had “unlimited funds” I would/will step up to the big Hyper-Therm machine for my table mount, but so far I am happy with the Little Razorweld. (Besides…..I am not sure I could lift a 1/2 plate that is 32x48 onto my table…..;):unsure: )
Brand names are kind of a “Snap-On Vs. Craftsman” type of debate…….Hard to say if the extra money is worth it or not?????🤷‍♂️….
From your project posts that I have seen, you seem to cut lots of “heavy duty” material, so you might benefit by stepping up to a larger amp'd machine. (70-80’ish???)
Air quality is important, and for some strange reason, it uses more air than what I originally expected…..(Don’t know why that is, but it did/does surprise me how long my little Quincy runs for 🤷‍♂️ 🤷‍♂️ )
Good luck sir, and make sure you post it when you get it!!!!
EDIT: As I was looking at my pictures, I noticed the respirator sitting there….That is one thing that I DID NOT ACCOUNT FOR…….I have to wear it when when cutting, or I get a “wicked sore throat” ….so I am reasonably sure it puts out “lots of bad sh1t”….Also, I have since “walled off” that area of my shop to keep “it” contained.
Just a heads up (y) (y)
Paul Allwood
Jul 8, 2025
467
740
The 2 brands stocked by the big tool suppliers close to me are Unimog and Cigweld.
Is the 60 to 70 A based on 115 V, and would it be the same as approx 30 to 35 A at 240 V ?
Paul Allwood
Jul 8, 2025
467
740
Thanks for the info. You're right, I do cut up to about 25 mm thick MS, but not too often. Given the step up in cost I think I'd be happy to stay with something that can cut 12 to 16 mm reasonably easily.
And yes, I'll definitely post pics when I get one. Maybe even a video of me trying to use it.
Yooper
3901 LA525
May 31, 2015
1,716
882
NE Wisconsin
As RWS touched on, you will need DRY compressed air or you are setting yourself up for failure. Not to mention going through a lot of consumables.
11,382
Having one that can use drag and gouging tips is invaluable IMHO. I have an older Hypertherm myself, but I've used a Thermal Dynamics one to.
Yes, the ability to gouge out welds is a valuable feature for sure. As in inveterate pack rat when it comes to steel I'm always repurposing stuff that invariably needs to be broken down before it can be built up. It's not a particularly efficient use of time, but there's something satisfying about it.
Kennyd4110
Vendor Member
Sep 7, 2013
1,486
856
Westminster, MD
www.boltonhooks.com
Exaclty.
Also make doing some repairs much easier, like replacing these tooth shanks on an small excavator bucket I did many years ago for my wife's cousin.
