P242d code
whitetiger
Nov 20, 2011
3,752
2,162
Kansas City, KS
Exhaust Gas Temperature Sensor 2 — T2 / DPF outlet sensor. It is the forward one in the muffler with a white connector. The wiring runs in front of the fuel tank.
The other 2 look the same, but one has a black connector; the other has a gray connector.
Check the connector and harness for an open circuit, loose connector, corrosion, or a short to +B
TxTom
L3301
Sep 16, 2022
32
15
Leon County, Tx
Thank you. Would it be ok to use the tractor some before doing that?
TxTom
L3301
Sep 16, 2022
32
15
Leon County, Tx
You were right on. A pin had pulled out of the white connector.
whitetiger
Nov 20, 2011
3,752
2,162
Kansas City, KS
Fantastic!! So you're good to go>>>>>>>>>>>>>>>>>>>
