P242d code
whitetiger
Nov 20, 2011
3,689
2,106
Kansas City, KS
Exhaust Gas Temperature Sensor 2 — T2 / DPF outlet sensor. It is the forward one in the muffler with a white connector. The wiring runs in front of the fuel tank.
The other 2 look the same, but one has a black connector; the other has a gray connector.
Check the connector and harness for an open circuit, loose connector, corrosion, or a short to +B
TxTom
L3301
Sep 16, 2022
31
14
Leon County, Tx
Thank you. Would it be ok to use the tractor some before doing that?
