Oops..dad mistakenly took pto lever for tranny lever
Jtryan
B2320
Jan 17, 2016
55
Ottawa, Ontario Canada
My dad helped me with yard work and was using my b2320 and wanted to shift from low to medium but used the pto lever and of course the gears grinded.
Should I be worried he damaged anything!? Everything seems fine.
2,279
It will not be the last time!;)
NO worries! :)
2,279
I guess it has happened with you a few times!?
I just hate the sounds of grinding gears
I'm always worried it causes internal damage
Especially these machines aren't cheap
On my 53 ford....I would have to grind a gear or 2 - that was a non synchronized tranny too! Had to be stopped to switch! :D:)
hodge
Nov 19, 2010
2,870
387
Love, VA
While not a pleasant sound, or something that should happen frequently, the gears are tough and can take some abuse. I'd be more worried if he jammed it into gear, versus grinding some. Be sure to educate him (I imagine that you did), and don't fret. It should be fine.
Jtryan
B2320
Jan 17, 2016
55
Ya it's not a pleasant sound for sure!
I hope to god he didn't pop it in! When I heard the grinding I ran over to see what he was doing!
I've used the pto a few times since and it seems ok but maybe it would break down the road!?
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
Been there. Went to drop the 3pt and shifted it into neutral instead. No gear grinding but man that thing took off like a rocket down the hill before my brain figured out what was happening and I hit the brake. :D
Corney
L1500DT, front end loader, mower, tiller, snow blower
My Dad has been using our L1500Dt up big time. Somewhere along the line someone put aftermarket stickers on the grey girl that are backwards on the 4x4 lever and the high/ low range.
My bride says I'm an arsehole cusse I laugh every time he is spinning out or doing a wheelie down the driveway?
pendoreille
B2620, fel, RB1560, Piranha Tooth Bar
Jan 2, 2015
476
Newport, WA
Had a 38 chev P\U with "crash box"...got pretty good at double clutching. Took a while when I got in a new vehicle to not double clutch
