OK to let bucket slam down to clear stuck snow in bucket?
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
I shake it. Any more than 3 times is playing with it though!
I also leave the bucket outside the garage. I back in, and unlatch it outside the door, it blocks the door so would be the thieves have another obstacle to getting stuff out. Sloshing some diesel fuel in the bucket will help with snow sticking too.
I was in the Navy seasick all the time and smelling diesel all the time. Hate that smell!
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
I would not recommend slamming it, and would never do that, even with someone elses equipment.
For the amount that actually sticks to the bucket while using it, why not leave it there, until the job is complete. Then use a scraper and snowbrush, to remove whatever is stuck, before moving the tractor to put it back in the garage, waiting for its next use.
I carry a shovel in the ballast box on the back and find myself stopping a lot to clear at least a 1/4 or almost 1/2 full of snow bucket.
leveraddict
Apr 1, 2019
907
592
NEPA
I took it the OP meant a quick dump and the bucket hits the stops dislodging snow. This is what I do usually only before pulling back in the garage!
mikester
M59 TLB
Oct 21, 2017
3,608
2,090
www.divergentstuff.ca
Having trouble understanding why this would be a NO.
If the tractor is stopped, and the bucket is just falling like in float, what would be the negative?
Just wondering what I am missing...
AG and garden tractors don't have robust pins and bushings. Impact loads are great for making your bushings oval. On construction equipment you can press out and replace the internal bushings. On your tractor its a major repair.
Not greasing your pins and bushings is also a form of abuse with similar results to slamming your buckets on the ground.
4,669
No, never let it hit the ground.
Much depends on how long it is allowed to "free fall". I am sure you remember:
v = at
followed by :
F = 1/2mv^^2
:unsure:
5,062
re: If the tractor is stopped, and the bucket is just falling like in float, what would be the negative?
he used the word 'slam', that to me means a very FORCEFUL action. If you watch/play hockey 'slamming someone into the walls is NOT a 'gentle' action !
As for 'sprays', all will be a one use deal. Move enough snow/ice, the 'spray' will be rubbed off. hmm, a spray paint, like the ceramic VHT ones, might work real slick.... there are spray on epoxy paints (RC hobby shops...) that might work. PREP of the bucket is 99.44% of the job...
4,669
As you may have noticed I am a bit of an empiricist and this piqued my interest. So when I took the trash down to the road this morning I did a little experimenting with an LA525 and and empty bucket.
  1. Float is self limiting - the cylinders act like a hydraulic damper and you get a controlled fall with soft landing.
  2. Full power down is a bit faster and you get a thump when you hit the ground (pavement in this case) but nothing exciting.
Findings: its next to impossible to "slam" the bucket on that loader against the ground.
5,062
hay Dan ...for YOUR tractor/loader combination,sounds like it's 'soft'
city JD TLB he COULD SLAM it down, hard.terrible abuse of the machine, course he doesn't OWN it....
re: Mortar ??? Yes..stuff used for brick laying. Idiots let the excess harden overnight, beat the drum to break it out of it, makes a helluva noise at 7AM, well anytime really....
2,996
That is my experience too. And the reason I was wondering what I was possibly missing...
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
213
76
Bloomsburg
If you continue to do things with your equipment that it was not intended for, you certainly risk damage. I buy the cheapest food spray I can find. I then spray my plow and loader with ample amounts just prior to using. This does seem to help some. I try to get the butter favor. It is what it is. The only issue I seem to have been keeping the dog from licking the spray off. LOL.
4,896
OK.. you got my attention since I haven't heard this word used in many years. For those that don't know what I am talking about, below is the explanation.
PHILOSOPHY
noun
  1. a person who supports the theory that all knowledge is based on experience derived from the senses.
    "most scientists are empiricists by nature"
adjective
  1. relating to or characteristic of the theory that all knowledge is based on experience derived from the senses.
    "his radically empiricist view of science as a direct engagement with the world"
4,669
PHILOSOPHY
noun
adjective
Not so much in the literal philisophical sense and more in the sense that I made my living in the test and measurement world. When a question is posed my immediate reaction is how do we quantify and gather empirical data (physics, chemistry, magnitude, duration, etc) that allows us to formulate a scientific answer or explanation for the question.
But I did take way more than the required minimum number of Philosophy credits 👍👍
