No, never let it hit the ground.Having trouble understanding why this would be a NO.
If the tractor is stopped, and the bucket is just falling like in float, what would be the negative?
Just wondering what I am missing...
I was in the Navy seasick all the time and smelling diesel all the time. Hate that smell!I shake it. Any more than 3 times is playing with it though!
I also leave the bucket outside the garage. I back in, and unlatch it outside the door, it blocks the door so would be the thieves have another obstacle to getting stuff out. Sloshing some diesel fuel in the bucket will help with snow sticking too.
Yes, curl dump control is what I mean as that is how I do it. Must be OK to do?Usually shaking the bucket with the curl/dump control gets the job done but I would have no qualms about a "gentle" rap on the ground. Free fall from full height - no.
Yes, this is what I mean raping it against the stops...must be OK do do then!I will run the bucket against the stops to dislodge stuck material but if a couple of those raps don't work, I just leave the stuff in .
I carry a shovel in the ballast box on the back and find myself stopping a lot to clear at least a 1/4 or almost 1/2 full of snow bucket.I would not recommend slamming it, and would never do that, even with someone elses equipment.
For the amount that actually sticks to the bucket while using it, why not leave it there, until the job is complete. Then use a scraper and snowbrush, to remove whatever is stuck, before moving the tractor to put it back in the garage, waiting for its next use.
AG and garden tractors don't have robust pins and bushings. Impact loads are great for making your bushings oval. On construction equipment you can press out and replace the internal bushings. On your tractor its a major repair.Having trouble understanding why this would be a NO.
Much depends on how long it is allowed to "free fall". I am sure you remember:Having trouble understanding why this would be a NO.
Standard operating practice.Yes, this is what I mean raping it against the stops...must be OK do do then!
Mortar ???yup, what gets me are the 'masons' who let the motor harden up overnight, then literally beat the krap outta the drum the next morning, at 7:12.......
As you may have noticed I am a bit of an empiricist and this piqued my interest. So when I took the trash down to the road this morning I did a little experimenting with an LA525 and and empty bucket.Having trouble understanding why this would be a NO.
That is my experience too. And the reason I was wondering what I was possibly missing...As you may have noticed I am a bit of an empiricist and this piqued my interest. So when I took the trash down to the road this morning I did a little experimenting with an LA525 and and empty bucket.
Findings: its next to impossible to "slam" the bucket on that loader against the ground.
- Float is self limiting - the cylinders act like a hydraulic damper and you get a controlled fall with soft landing.
- Full power down is a bit faster and you get a thump when you hit the ground (pavement in this case) but nothing exciting.
OK.. you got my attention since I haven't heard this word used in many years. For those that don't know what I am talking about, below is the explanation.As you may have noticed I am a bit of an empiricist and this piqued my interest. So when I took the trash down to the road this morning I did a little experimenting with an LA525 and and empty bucket.
Not so much in the literal philisophical sense and more in the sense that I made my living in the test and measurement world. When a question is posed my immediate reaction is how do we quantify and gather empirical data (physics, chemistry, magnitude, duration, etc) that allows us to formulate a scientific answer or explanation for the question.OK.. you got my attention since I haven't heard this word used in many years. For those that don't know what I am talking about, below is the explanation.
PHILOSOPHY
noun
adjective
- a person who supports the theory that all knowledge is based on experience derived from the senses.
"most scientists are empiricists by nature"
- relating to or characteristic of the theory that all knowledge is based on experience derived from the senses.
"his radically empiricist view of science as a direct engagement with the world"
But sometimes it's worth it?If you continue to do things with your equipment that it was not intended for, you certainly risk damage.
Probably benefited more from taking those classes than what basket weaving might have given you...LOLBut I did take way more than the required minimum number of Philosophy credits
