New To The Tractor World
jeffrockhall
M7060
May 17, 2025
Hebron, Maryland
I have M7060 with a Wallenstein chipper is there a certain way to hook up the hydraulic hoses on the rear remote? Is there a pressure side and return side to the remote and finally is there a certain order one must go in first?
JasonW
867
583
Al
What part of the chipper is hydraulic? In feed or chute rotation? What model?
The rear remotes on the tractor can be both pressure side depending which way the remote lever is actuated.
jeffrockhall
M7060
May 17, 2025
Hebron, Maryland
The chipper is a Wallenstein 102RI the indeed rollers are hydraulic. Tractor 2026 m7060
Bee-Positive
Nov 16, 2022
1,096
1,018
Amsterdam, NY
Not sure if it matters. The users manual makes no mention of which hose goes where, just says to connect them. The chipper has a roller feed control bar that operates a valve to change the direction of the feed rollers.
Hook the hoses to the tractor and operate the chipper. See if the feed rollers function as described on page 25 of the owners manual. If not see if switching the hoses on the rear remotes changes the rotation of the feed rollers.
Side note: you're probably aware that the chipper requires 4-8 GPM and you will have to adjust the flow control valve on the chipper as stated on page 24.
3,113
You say “rear remote” but that really is ambiguous. I think you mean a rear remote VALVE, but you may mean the rear backhoe connection points.
A valve will apply flow out of either cylinder hose depending on where the lever is placed. As soon as you release the lever the flow to the implement stops (On most valves). There are valves that will hold the flow on but they are not commonly selected for rear remote valves, not unheard of but just not common. If that type of valve is used then the continuous flow path is set and you would need to know which hose out of the valve has continuous flow.
The rear connection points for a back hoe are definitely set up with one being supply and the other being return to the tractor. There again you will need to know which is which to get your hydraulics working correctly for in-feed operation to be correct.
Post a picture of what you are calling “rear remote”.
So the short answer is that the flow to the chipper is probably not directional since the bar can reverse the direction of the roller. And it does not matter which one is connected first or second. And the tractor should probably be not running when you connect the hydraulic lines to make it easier and safer.
