New To The Tractor World
jeffrockhall
M7060
May 17, 2025
Hebron, Maryland
I have M7060 with a Wallenstein chipper is there a certain way to hook up the hydraulic hoses on the rear remote? Is there a pressure side and return side to the remote and finally is there a certain order one must go in first?
JasonW
805
558
Al
What part of the chipper is hydraulic? In feed or chute rotation? What model?
The rear remotes on the tractor can be both pressure side depending which way the remote lever is actuated.
Bee-Positive
Nov 16, 2022
1,016
957
Amsterdam, NY
Not sure if it matters. The users manual makes no mention of which hose goes where, just says to connect them. The chipper has a roller feed control bar that operates a valve to change the direction of the feed rollers.
Hook the hoses to the tractor and operate the chipper. See if the feed rollers function as described on page 25 of the owners manual. If not see if switching the hoses on the rear remotes changes the rotation of the feed rollers.
Side note: you're probably aware that the chipper requires 4-8 GPM and you will have to adjust the flow control valve on the chipper as stated on page 24.
