New Member here with L2502 smoking TSB
Andyr9981
L2502 HST
Feb 10, 2026
9
12
Coleman, Michigan
Hello All!
Wanted to say hello as a New member here with a L2502 purchased new in 2024, I had rather gotten used to the smoke with this machine being it’s not a diesel engine with emissions equipment, but with the cold starts here in Michigan without a block heater although I was able to fire up at any temp I did think that the smoke was a bit excessive.. and so an internet search revealed my model had a Technical service bulletin for this issue. I verified with my dealer yesterday, and they are ordering parts for me. If I read correctly there are shims in this fuel pump which if they remove one or more of them this advances the fuel timing to help more complete the power stroke without wasting as much fuel out the exhaust? Not sure how much more power I should gain or RPM? Does anyone have some information who might have had this done already on how it runs after this dealer fix?
Thank you all in advance!
5,488
Welcome and congratulations on your new machine.👏
I have heard of this, but I am not “up to snuff” on the particualrs. Although I would not expect a significant difference in power/rpm.
The more curious thing is why your dealer even stocked a tractor WITHOUT a block heater.:unsure:(considering your latitude.)
Anyway, nice tractor, and good luck sir(y)
Trash Panda
L2501
Feb 18, 2022
287
270
Wyoming
The dealer technically has their hands tied, as they can’t perform any work that would cause the engine output to climb above 25hp. Sounds like they are changing the injection timing, which is a popular modification on that particular engine.
If you don’t like the smoke on a cold start, have them add a block heater while it’s being worked on. It’s a cheap addition that makes a world of difference, and it is easier on the machine when used.
Andyr9981
L2502 HST
Feb 10, 2026
9
12
Coleman, Michigan
I am shocked also that Tractor did not come with block heater.
Trustable
l2501HST
Jul 5, 2022
397
411
I got my tractor in clare, it does not have a block heater, now that I’m more north I really wish I had one, I keep it in a heated garage that negates the purpose but would be nice on the times I have to keep it outside or in a shed depending on what’s in the garage.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,946
2,451
WestTn/NoMs
Hello All!
I've read one or two reports on here about folks having the TSB done. I think it involves pump shims, but I wouldn't expect to start tractor pulling. For that you need the turbo kit.
5,488
Huh……I guess I was just lucky then.
I bought mine at a place near my cottage, (Ginops of Hillman) since I figured that would be the place it spends most of it’s time, and although I did not “specify” a block heater, there is one. 🤷‍♂️
Trustable
l2501HST
Jul 5, 2022
397
411
haha sounds like it! I am gonna have to look into what it takes to install one before committing.
whitetiger
Nov 20, 2011
3,747
2,162
Kansas City, KS
1: Drain coolant
2: Remove the soft plug
3: Install the sleeve into the soft plug hole
4: Screw the heater into the sleeve
5: Refill with coolant
Andyr9981
L2502 HST
Feb 10, 2026
9
12
Coleman, Michigan
Forgot to update my results from the fuel pump shim removal.. the dealer was advised by Kubota to removed .05 thousands shim After measurement of the factory shims. Now I’ve been in warm weather of course (actually insane heat in Michigan) right now but it definitely smokes much less! I think I gained a little RPM as well. Everything was covered by Kubota as expected for my complaint. Tractor is in shop now for left rear differential leak, and I’m almost to 2 year mark in mid July.
7,320
Would you care to clarify how much they removed? I dont think it was .05 thousandths (.00005).
