Never owned a Tractor
Bearcatrp
Mar 28, 2023
1,325
969
Minnesota
Congrats on the new tractor. Should serve you well for years to come. Have to stop reading these posts of folks getting a new tractor. Gives me that itch to go get that LX2620 I want. Would probably end up sleeping on it as the wife would banish me from the house if I can home with a new tractor. :mad:
Blue2Orange
Apr 3, 2025
398
277
Bayview Township
Enjoy the new tractor. I downsized to the BX. Just a casual tractor user. Another low hour year of use. Low 80's over the BX's first 12 months of use. Driveway maintenance (smoothing and snow removal), hauling and moving firewood logs. Deep(+20") or heavy wet snow blowing is much slower with the BX. You will appreciate the HP, mass of tractor. Went from couple decades of R1s with no chains to R4s with rear chains. You might want to consider at least rear chains if ice or hard pack driveway surface and any pitch. I think I made the mistake of going with 2 link ladder chains v. the euro diamond or H pattern chains. The BX definitely needs front chains or studs for our snow conditions.
Haven't ever used a land plane/grader scraper. Do own a box scraper. In addition to what it is designed to do it serves and rear ballast for bucket or grapple use. Snowblower is rear mounted. But for your use the added mass might be beneficial while using your front mounted snowblower. Might be able to use to pull snow away from objects you would not want to run into with your front blower. Others can comment if a stupid idea or practical use. Took a while to more or less get semi-competent using it to grade the driveway. Initially it was handy for moving and distributing the 80 tons of gravel purchased last year to "top coat" the driveway. No ruts or cuts with the blue rock gravel. Mostly just distributing and smoothing. Thinking land plane would have been the better choice for my specific needs, but the used good priced box was sitting there. All the land planes were new and significantly more $$$s.
Grandad4
Apr 5, 2016
426
183
Greensboro, NC
Each implement has it's advantages. With your snow blower mounted up front, something heavy in back, like an offsetting scraper blade would put more weight on the rear tires for better traction. In addition to warm weather chores, that blade can also move snow, which can sometimes be useful even with the blower.
I didn't see any mention of a front end loader, which many find to be the single most useful addition to a compact tractor.
Lowlysubaruguy
b7800 l4701
Oct 3, 2025
69
19
Big Island
Congrats.
I bought my third Friday. i say this with a smile but it’s pretty much the truth. I never worked so hard in my life until I bought my first tractor. Maybe you can go at things from a different approach than me. i built on a swamp now I’m building in a jungle.
wsurff
L6060, Backhoe, Front Snow Blower, Grapple, Chipper, Box Blade
Oct 8, 2021
60
44
NJ
More info on this would be great because I have no clue about the Box Scraper. My drive slopes so all the water from snow melt and rain do a number on the bottom of the drive. I figured why pay someone to fix it when I am buying a tractor. Is the Box Scraper the tool I need to level out the driveway or should I be looking at something different? The deal is not yet so I can still change the order. I also would like to scrap up the melting slush during the melt downs of the snow.
Congratulations on your new machine and welcome to OTT!
Another vote for the Land Leveler/ Land plane for your gravel driveway. I have both implements. I started out with the box blade. If you're going that route, a hydraulic top link would be a great addition and make your life much easier. No doubt, land plane is much more of a no-brainer with regard to the need to adjust the top link frequently until you find the right angle that does the job most efficiently for your driveway conditions. With the land plane, it's just basically drop it and drive. My land plane has scarifiers as well, and I will make fine adjustments with the top link at times with the scarifiers down, but not as frequently as with the box blade.
