i currently have no external hydraulics and my ports are still capped. i am adding a loader with it's own valve controls. i guessing i remove the four bolts to the cap and was told that a block bolts on it which will have the threads to screw in my hydraulic hoses. if that is correct do you know where i can find that block and what it is called or part number, or can i just have a machinist make a block with matching ports that line up with two threaded ports. from the parts pictures i have seen the block on the tractor has the o-ring grooves. so i am picturing a block that is flat on bottom. am i right or way off?
