need to dig shallow trenches - no backhoe
hoosier_chuck
B2401DT
May 16, 2026
Indiana
Anyone have any good implement suggestions to use for digging multiple shallow trenches for some drainage? Kubota B2401DT is the compact tractor that I will attach to.
Thank you
3,088
Used one many times before - down to about 8 inches it work well depending on soil type
jaxs
B1750HST
Jun 22, 2023
1,103
828
Yup, what he^^^ said then remove loose soil with 3 point scoop or shovel and wheel barrow.
Shawn T. W
Dec 9, 2024
833
1,509
SW Missouri Ozarks
How "deep" is "shallow"?
Damp dirt digs easier ...
I've used the bucket ...
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
791
1,467
Baranduda, Victoria, Australia
I made this single tyne ripper a while ago to dig shallow trenches. I tested and it worked well. The next step was to add a pipe laying attachment but haven't got to that yet.
Obviously the depth and ease of dragging it through depends on the soil conditions, but I reckon if it can work on my 40 year old 17 HP tractor it should work better on yours.
In the video I was attempting unsuccessfully to remove a large root from a large tree.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,960
2,460
WestTn/NoMs
I thought someone had suggested this - use your forks, or one fork, then clean it out with a hoe or shovel. You wouldn't want to do a whole lot this way, but it can be done.
ken erickson
Nov 21, 2010
1,439
2,673
Waupaca Wisconsin
Yes, this could work. Not very deep. burying multiple 3" drains.
Second using your bucket depending on soil type etc.
I dug just shy of 300 feet for a 4 inch drain using my bucket only. I was surprised at the depth I was able to achieve, and took me about 1 1/2 hours not including back fill.
Caden
1979 B7100
Apr 16, 2026
329
188
Not having a fel, I've done a mild ditch with my rear angle blade.
Used all the level adjustment in the blade its self plus the level adjustment in the 3ph, and then rotated the blade with short toplink. It gets the front corner to cut at a very acceptable angle.
It works on dirt, I don't know about heavy roots or rocky soil.
Bee-Positive
Nov 16, 2022
1,176
1,087
Amsterdam, NY
Clay and rock, lots of rocks!!!
Dug a trench for the 40' wall footer with my bucket and BXpanded tooth bar.
Sidekick
Jul 29, 2023
1,286
1,864
N.Y,
I have one of these that works good if no big rocks or roots.
4,242
I successfully dug a 150’ long french drain more than a foot deep using an ordinary single-blade scraper….. by tilting the 3-pt as extreme as it would go…and using the low-side / end of the blade.
jaxs
B1750HST
Jun 22, 2023
1,103
828
AS they say, there's more than one way of skinning cats. Looks like that also holds true for shallow trenches. Now to figure out the best way to fill them in when no longer needed.
