My Next Stupid Question regarding PTO power.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,977
Near Lancaster, PA, USA
And if it takes 10HP to propel the tractor, that leaves how many HP to run equipment while moving?
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,465
656
Richmond, Virginia
Only one guy actually answered (correctly I hope). Never said it was my BX (and it is not) Never said I'd be using HP other than at the PTO (I wont be)
I'm thinking a chipper on my other 'Green' tractor. My BX digs/moves dirt and pulls stuff.
Caden
1979 B7100
Apr 16, 2026
265
144
How bout you find the info you need in the manual of whatever mystery tractor you are refering to.
JasonW
864
583
Al
At least the title of this thread is correct.
jaxs
B1750HST
Jun 22, 2023
1,095
823
Sounds like he already knew and only wanted to see how many others know or could correctly guess..
William1
Jul 28, 2015
1,465
656
Richmond, Virginia
No,
No, I was curious if people had the knowledge. It was a simple question. How many HP is at a PTO of a tractor with a 24 HP diesel..I really did not need to know how fast a Swallow can fly.
William1
Jul 28, 2015
1,465
656
Richmond, Virginia
You know, I've read it a few times and did not find that spec, hence my question. I've found most of the members here are typically more knowledgeable and courteous. The 'Green' forum, most of the guys are rather clueless.
My limited knowledge is the brand of tractor does not matter, it is engine HP then at the PTO is typically X for ANY machine.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
132
133
Lakes Region, NH
Actually the PTO hp relative to the engine HP is not a fixed percentage and does vary somewhat brand to brand and also depends on the type of transmission, i.e. geared vs HST. A simple online search for specs of the particular tractor in question will usually result in finding the answer.
Caden
1979 B7100
Apr 16, 2026
265
144
PTO hp might be similar, but it is not the same across the board. How much power is transferred to the PTO depends on transmission type, as well as other accessories like a hydro pump that the engine is running ahead of the PTO. That said, @mikester gave an answer that should be sufficient.
Any decent owners manual ought to tell you pto hp, If it doesn't I'd call a dealer an ask. I think that would get you a better answer than having us guess.
Not really sure what you meant be your comment on courteousness, or on the speed of Swallows... :unsure:
JasonW
864
583
Al
Well let me tell you it absolutely matters. That’s why to provide a better/accurate answer, the first question to ask is what model tractor. Beyond that it’s just a guess.
Instead of the guessing games of what tractor you’re even talking about or the speed or fowl.
11,125
Note: An HST tractor uses some HP even when it's not in motion.
Also if there is any hydro load that will effect HP output.
bird dogger
Feb 24, 2019
1,802
1,773
North Dakota
Another interesting variable that comes to mind is the fact that determines what one horsepower is. Going back to basic physics: It takes 1 HP to raise 550 lbs. 1 foot in 1 second. If you're running your tractor uphill with a loaded bucket, rear implement, (maybe loaded tires), etc., its not hard to calculate the engine HP it takes to just move the complete unit uphill at the speed you've selected..... before accounting for any HP left over to apply to the various ptos or any ground engaging implements.
William1
Jul 28, 2015
1,465
656
Richmond, Virginia
Ball Park 75% or 24 x .75 = 18 hp at the PTO. YMMV
My BX1880 has 13.7 hp at the PTO
18 x 75% = 13.5 hp
This was my 'wild guess', a 25% ;loss' when stationary Hydraulics not working but fully pressurized sucking up power, more on a HST tractor due to a larger hydraulic pump.
Thank you very much.(y)
